A curated list of amazingly awesome open-source sysadmin resources.
2023-08-12 09:22:32 +02:00
.github Fixed link leading to the same repo (#495) 2023-06-01 14:35:54 +00:00
.hecat replace travis CI with github actions (check syntax, check links) 2023-03-29 00:55:23 +02:00
LICENSE.txt Add CC BY-SA 4.0 International license 2015-04-09 13:05:50 +02:00
Makefile replace travis CI with github actions (check syntax, check links) 2023-03-29 00:55:23 +02:00
README.md Fix Typo in lang and remove \n 2023-08-12 09:22:32 +02:00
certified awesome!
^ back to top ^
  • Gradle - Another build automation system. (Source Code) Groovy/Java Apache-2.0
^ back to top ^
^ back to top ^
^ back to top ^
  • Errbot - a plugin based chatbot designed to be easily deployable, extensible and maintainable. (Source Code) GPL-3.0 Python
^ back to top ^
Related: IT Asset Management
^ back to top ^
  • Clonezilla - Partition and disk imaging/cloning program. (Source Code) GPL-2.0/Other Perl/Shell/Other
  • Fog - Cloning/imaging solution/rescue suite. (Source Code) GPL-3.0 PHP/Shell
^ back to top ^
  • CloudSlang - Flow-based orchestration tool for managing deployed applications, with Docker capabilities. (Source Code)
  • CloudStack - Cloud computing software for creating, managing, and deploying infrastructure cloud services. (Source Code)
  • Cobbler - Cobbler is a Linux installation server that allows for rapid setup of network installation environments. (Source Code)
  • Overcast - Deploy VMs across different cloud providers, and run commands and scripts across any or all of them in parallel via SSH. (SOurce Code)
^ back to top ^
^ back to top ^
^ back to top ^
  • Ansible - Provisioning, configuration management, and application-deployment tool. (Source Code)
  • CFEngine - Configuration management system for automated configuration and maintenance of large-scale computer systems. (Source Code)
  • Chef - Configuration management tool using a pure-Ruby, domain-specific language (DSL) for writing system configuration "recipes". (Source Code)
  • Puppet - Software configuration management tool which includes its own declarative language to describe system configuration. (Source Code)
  • Salt - Event-driven IT automation, remote task execution, and configuration management software. (Source Code)
^ back to top ^
^ back to top ^
  • Cockpit - web-based graphical interface for servers. (Source Code) LGPL-2.1 C
  • VestaCP - Open-Source hosting control panel. (Source Code) GPL-3.0 PHP/Shell/Other
^ back to top ^
Deployment Automation
^ back to top ^
^ back to top ^
Distributed Filesystems
^ back to top ^
^ back to top ^
  • djbdns - A collection of DNS applications, including tinydns. (Source Code) Public Domain C
^ back to top ^
Related: DNS - Servers
^ back to top ^
  • Atom Community - A fork of atom A hackable text editor from Github.
  • Geany - GTK2 text editor.
  • VSCodium - An open source cross-platform extensible code editor based on VS Code by Microsoft removing their non-free additions.
^ back to top ^
Identity Management - LDAP
^ back to top ^
^ back to top ^
  • ZITADEL - Cloud-native Identity & Access Management solution providing a platform for secure authentication, authorization and identity management.
^ back to top ^
^ back to top ^
  • GLPI - Information Resource-Manager with an additional Administration Interface. (Source Code)
^ back to top ^
  • Flume - distributed, reliable, and available service for efficiently collecting, aggregating, and moving large amounts of log data. (Source Code) Apache-2.0 Java
^ back to top ^
^ back to top ^
  • Bosun - Monitoring and alerting system by Stack Exchange (Source Code) MIT Go
  • Cabot - Monitoring and alerts, similar to PagerDuty. (Source Code) MIT Python
  • cadvisor - Analyzes resource usage and performance characteristics of running containers (Source Code) Apache-2.0 Go
  • checkmk - Comprehensive solution for monitoring of applications, servers, and networks. (Source Code) Python/PHP
  • PHP Server Monitor - Open source tool to monitor your servers and websites. (Source Code)
  • PhpSysInfo - A customizable PHP script that displays information about your system nicely. (Source Code)
  • pyDash - Small web-based monitoring dashboard for linux. (Source Code)
  • Riemann - Flexible and fast events processor allowing complex events/metrics analysis. (Source Code)
  • rtop - an interactive, remote system monitoring tool based on SSH. (Source Code)
  • ruptime - classic system status server (Source Code) AGPL-3.0 Shell
  • Scrutiny - Hard Drive S.M.A.R.T Monitoring, Historical Trends & Real World Failure Thresholds
  • Sensu - Monitoring tool for ephemeral infrastructure and distributed applications. (Source Code)
  • Thruk - Multibackend monitoring web interface with support for Naemon, Nagios, Icinga and Shinken. (Source Code)
  • Zabbix - Enterprise-class software for monitoring of networks and applications. (Source Code)
^ back to top ^
^ back to top ^
  • Beats - Single-purpose data shippers that send data from hundreds or thousands of machines and systems to Logstash or Elasticsearch. (Source Code) Apache-2.0
  • Statsd - Daemon that listens for statistics like counters and timers, sent over UDP or TCP, and sends aggregates to one or more pluggable backend services. Nodejs MIT
^ back to top ^
^ back to top ^
^ back to top ^
Public Key Infrastructure - PKI
^ back to top ^
  • BounCA - A personal SSL Key / Certificate Authority web-based tool for creating self-signed certificates. Apache-2.0 Python
  • easy-rsa - bash script to build and manage a PKI CA. GPL-2.0 bash
  • openxpki - A software stack based on perl and openssl to run a PKI/trust center with an enterprise-grade feature set. Apache-2.0 perl
  • Smallstep Certificates - A private certificate authority (X.509 & SSH) and related tools for secure automated certificate management. Apache-2.0 Go
  • TinyPki is a compact and secure PKI, designed for Home, Lab, and Development environments, enabling you to effortlessly create a Root Certificate Authority and generate certificates to fulfill various requirements. MIT Go
^ back to top ^
^ back to top ^
Remote Desktop Clients
^ back to top ^
  • Remmina - Feature-rich remote desktop application for linux and other unixes. (Source Code)
  • Tiger VNC - High-performance, multi-platform VNC client and server. (Source Code)
  • X2go - X2Go is an open source remote desktop software for Linux that uses the NoMachine/NX technology protocol. (Source Code)
  • OPNsense - An open source FreeBSD-based firewall and router with traffic shaping, load balancing, and virtual private network capabilities. (Source Code) BSD-2-Clause C PHP
^ back to top ^
  • etcd - distributed K/V-Store, authenticating via SSL PKI and a REST HTTP Api for shared configuration and service discovery. (Source Code) Apache-2.0 Go
^ back to top ^
  • LXD a container "hypervisor" and a better UX for LXC. (Source Code) Apache-2.0 Go
^ back to top ^
^ back to top ^
^ back to top ^
^ back to top ^
  • Dockovpn - Out-of-the-box stateless dockerized OpenVPN server which starts in less than 2 seconds.
  • Firezone - WireGuard based VPN Server and Firewall.
  • Headscale - Self-hostable fork of Tailscale, cross-platform clients, simple to use, built-in (currently experimental) monitoring tools.
  • sshuttle - Poor man's VPN.
  • tinc - Distributed p2p VPN.
^ back to top ^
cc license
