| .hecat | ||
| Makefile | ||
- Client management
- DNS - Control Panels
- DNS - Domain Management
- Metric & Metric Collection
- Newsletters
- Blogs
- Books
- Newsletters
MITRuby
See also: IT Asset Management
Apache-2.0C#/PowerShell
GPL-3.0PHP/Shell
BSD-3-ClauseC - PowerDNS Authoritative Server - Versatile nameserver which supports a large number of backends.. (Source Code)
BSD-3-ClauseC
DNS server control panels.
ISCPerl - Pi-hole - A blackhole for Internet qdvertisements with a GUI for management and monitoring. (Source Code)
EUPL-1.2Shell/PHP - Poweradmin - Web-based DNS control panel for PowerDNS server. (Source Code)
GPL-3.0PHP
MITPython
OLDAP-2.8C
GPL-3.0C
See also: Databases
Apache-2.0Python - RRDtool - Industry standard, high performance data logging and graphing system for time series data.
GPL-3.0PHP
BSD-2-ClauseCPHP
GPL-2.0C
BSD-2-ClauseC
