| .hecat | ||
| Makefile | ||
- Client management
- DNS - Control Panels
- DNS - Domain Management
- Metrics & Metric Collection
- Newsletters
- Blogs
- Books
- Newsletters
MITRuby
- Amanda - Client-server model backup tool. (Source Code)
MITC - Backupninja - Lightweight, extensible meta-backup system.
GPL-2.0Shell - BackupPC - BackupPC is a high-performance system for backing up to disk. (Source Code)
GPL-3.0Perl - Bareos - A fork of Bacula backup tool. (Source Code)
AGPL-3.0C++/C - Barman - Backup and Recovery Manager for disaster recovery of PostgreSQL servers. (Source Code)
GPL-2.0C++ - Duplicati - Multiple backends, encryption, web-ui and multi-OS backup tool. (Source Code)
GPL-3.0Rust - rclone - a command line program to sync files and directories to and from several cloud storage systems/providers. (Source Code)
MITGo - Rdiff-backup - An easy A remote incremental backup of all your files. (Source Code)
GPL-2.0Python - Restic - Secure, remote backup tool. Designed to be easy, fast, verifiable and efficient. (Source Code)
BSD-2-ClauseGo - Rsnapshot - Filesystem Snapshotting Utility. (Source Code)
MITGo - UrBackup - Another client-server backup system. (Source Code)
AGPL-3.0C/C++
See also: IT Asset Management
Apache-2.0C#/PowerShell
GPL-3.0PHP/Shell
BSD-3-ClauseJava
BSD-3-ClauseC - PowerDNS Authoritative Server - Versatile nameserver which supports a large number of backends.. (Source Code)
BSD-3-ClauseC
DNS server control panels.
ISCPerl - Pi-hole - A blackhole for Internet qdvertisements with a GUI for management and monitoring. (Source Code)
EUPL-1.2Shell/PHP - Poweradmin - Web-based DNS control panel for PowerDNS server. (Source Code)
GPL-3.0PHP
MITPython
OLDAP-2.8C
GPL-3.0C
See also: Metrics & Metric Collection
See also: Databases, Monitoring
MITGo
GPL-3.0PHP
GPL-2.0Python
GPL-3.0C++
Apache-2.0Shell/PHP/Other
GPL-2.0C
BSD-2-ClauseC
