| .hecat | ||
| Makefile | ||
- Awesome Sysadmin
- Table of contents
- Client management
- Identity Management - Single Sign-On (SSO)
- Metrics & Metric Collection
- Newsletters
- Remote Desktop Clients
MITRuby
AGPL-3.0C/C++
MITLua - HPCBIOS - HPCBIOS is an effort to setup a common, well-documented and reproducible, environment spanning across multiple HPC systems & sites, inclusive of documentation.
- Spack - A flexible package manager that supports multiple versions, configurations, platforms, and compilers. (Source Code)
MIT/Apache-2.0Python
Related: IT Asset Management
Apache-2.0C#/PowerShell
GPL-2.0/OtherPerl/Shell/Other - Fog - Cloning/imaging solution/rescue suite. (Source Code)
GPL-3.0PHP/Shell
GPL-2.0Python - Genesis - A template framework for multi-environment BOSH deployments.
MITPerl - Overcast - Deploy VMs across different cloud providers, and run commands and scripts across any or all of them in parallel via SSH. (Source Code)
Apache-2.0Python
Apache-2.0Python
MITRuby - Fabric - Python library and cli tool for streamlining the use of SSH for application deployment or systems administration tasks. (Source Code)
BSD-2-ClausePython - Mina - Really fast deployer and server automation tool (rake based). (Source Code)
Apache-2.0Python - Vlad the Deployer - Deployment automation (rake based).
MITRuby
MITNodejs/Docker
BSD-3-ClauseJava
BSD-3-ClauseC
Related: DNS - Servers
MITPHP
GLP-3.0JavaScript - ICEcoder - Code editor awesomeness, built with common web languages. (Demo, Source Code)
GFDLv1.2C++ - Micro - A modern and intuitive terminal-based text editor. (Source Code)
MITTypeScript
OLDAP-2.8C
Apache-2.0Python - easy-rsa - bash script to build and manage a PKI CA.
AGPL-3.0Python - OpenID Connect - A Simple Identity layer on top of OAuth 2.0.
- Pomerium - An identity and context aware access-proxy inspired by BeyondCorp. (Source Code)
Apache-2.0Docker/Go - Samba – Active Directory and CIFS protocol implementation. (Source Code)
Apache-2.0Go/Docker/K8S
GPL-3.0C
MITGo
GPL-3.0PHP
GPL-2.0Perl - Lewsnetter - E-mail marketing application (create and send e-mail newsletter via SES). Includes subscription management, delivery, bounce and complaint notification, templates, and some stats.
GPL-2.0Python
GPL-3.0C++
GPL-2.0Perl
Apache-2.0Shell/PHP/Other
Apache-2.0Java/C++
GPL-2.0C
- grml – bootable Debian Live CD with powerful CLI tools. (Source Code)
GPL-2.0C
BSD-2-ClauseC
