THIS LIST HAS BEEN DEPRECATED IN FAVOUR OF THE TILDE AWESOME-SYSADMIN FORUM.
THE GITHUB REPOSITORY HAS BEEN ARCHIVED.
- Awesome Sysadmin
- Client Management
- DNS
- Domains
- Metric & Metric Collection
- Newsletter
- NoSQL
- RDBMS
- SSH: see awesome-ssh
- Resources
- Flynn - PaaS
- Web hosting
- DNS
- Server
DNS
Domains
LDAP
- OpenDJ - Fork of OpenDS.
Tools and web interfaces
- netcheck – Simple ping status system written in Java, similar to Pingdom and StatusCake.
Collectors only
Dashboards
Storage
NoSQL
NoSQL databases.
- Column-Family
- Document Store
- Graph
- Key-Value
RDBMS
Relational DBMS.
Resources
Debian-based distributions
RPM-based distributions
Wikis
