- ref. https://github.com/awesome-foss/awesome-sysadmin/pull/357 - ref. https://github.com/awesome-foss/awesome-sysadmin/pull/449 - ref. https://github.com/awesome-foss/awesome-sysadmin/pull/453 - ref. https://github.com/awesome-foss/awesome-sysadmin/pull/457 - ref. https://github.com/awesome-selfhosted/awesome-selfhosted/pull/3217 - ref. https://github.com/awesome-foss/awesome-sysadmin/pull/429 - ref. https://github.com/awesome-foss/awesome-sysadmin/pull/377 |
- Client management
- DNS - Control Panels
- DNS - Domain Management
- Metric & Metric Collection
- Newsletters
- Blogs
- Books
- Newsletters
See also: IT Asset Management
Apache-2.0C#/PowerShell
GPL-3.0PHP/Shell
DNS server control panels.
MITPython
- OpenDJ - Fork of OpenDS.
- Thruk - Multibackend monitoring web interface with support for Naemon, Nagios, Icinga and Shinken. (Source Code)
Collectors only
Dashboards
Storage
GPL-3.0PHP
BSD-2-ClauseCPHP
