- Awesome Sysadmin
- Client Management
- DNS
- Domains
- Metric & Metric Collection
- Newsletter
- NoSQL
- RDBMS
- SSH: see awesome-ssh
- Resources
See also: IT Asset Management
- Web hosting
- DNS
- Server
DNS
Domains
LDAP
- OpenDJ - Fork of OpenDS.
Tools and web interfaces
ApacheGo - checkmk - Comprehensive solution for monitoring of applications, servers, and networks. (Source Code)
Collectors only
Dashboards
Storage
NoSQL
NoSQL databases.
- Column-Family
- Document Store
- Graph
- Key-Value
RDBMS
Relational DBMS.
- Podman - is a daemonless container engine for developing, managing, and running OCI Containers on your Linux System. Containers can either be run as root or in rootless mode. Simply put: alias docker=podman (Source Code)
Apache-2Go - Buildah - a tool that facilitates building OCI container images (Source Code)
Apache-2Go - LXC - Userspace interface for the Linux kernel containment features.
Resources
Debian-based distributions
RPM-based distributions
Wikis
