- mark as related to awesome-selfhosted/Remote Access - ref. https://github.com/awesome-foss/awesome-sysadmin/issues/404 |
| .hecat | ||
| Makefile | ||
- Client management
- Metrics & Metric Collection
- Newsletters
- Remote Desktop Clients
- Blogs
- Books
- Newsletters
MITRuby
AGPL-3.0C/C++
Related: IT Asset Management
Apache-2.0C#/PowerShell
GPL-3.0PHP/Shell
BSD-3-ClauseJava
BSD-3-ClauseC
Related: DNS - Servers
MITPHP
OLDAP-2.8C
GPL-3.0C
MITGo
GPL-3.0PHP
GPL-2.0Python
GPL-3.0C++
Apache-2.0Shell/PHP/Other
Apache-2.0Java/C++
GPL-2.0C
BSD-2-ClauseC
