- Awesome Sysadmin
- Client management
- DNS
- Domains
- Newsletters
- NoSQL
- RDBMS
- Resources
- Flynn - PaaS
- Web hosting
- DNS
- AdGuardHome - Network-wide ads & trackers blocking DNS server.
- Server
DNS
Domains
LDAP
- OpenDJ - Fork of OpenDS.
Tools and web interfaces
- Uptime Kuma - Self-hosted status page similar to "Uptime Robot".
- netcheck – Simple ping status system written in Java, similar to Pingdom and StatusCake.
Metric & Metric Collection
Collectors only
Dashboards
Storage
NoSQL
NoSQL databases.
- Column-Family
- Document Store
- Graph
- Key-Value
RDBMS
Relational DBMS.
Resources
Debian-based distributions
RPM-based distributions
Wikis
