- there are countless good sysadmin resources of these types, maitaining a comprehensive list here would take too much time, out of scope
- the resources listed here are either too specific, or can easily be found by web search, or low-quality ("7 Proven Tips to Boost Your Passive Income from Affiliate Marketing"...)
- this leads to "spammy" pull requests/issues from people wanting to promote their own blog
- if someone wants to maintain a third-party list of good blogs/books/newsletters please make yourself known through the project issues
| .hecat | ||
| Makefile | ||
- Client management
- DNS - Control Panels
- DNS - Domain Management
- Metric & Metric Collection
- Newsletters
- Blogs
- Books
- Newsletters
See also: IT Asset Management
Apache-2.0C#/PowerShell
GPL-3.0PHP/Shell
DNS server control panels.
MITPython
OLDAP-2.8C
AGPL-3.0Go
Collectors only
Dashboards
Storage
GPL-3.0PHP
BSD-2-ClauseCPHP
GPL-2.0C
