| .hecat | ||
| Makefile | ||
- Client management
- Metrics & Metric Collection
- Newsletters
- Remote Desktop Clients
- Blogs
- Books
- Newsletters
MITRuby
AGPL-3.0C/C++
Related: IT Asset Management
Apache-2.0C#/PowerShell
GPL-3.0PHP/Shell
Please visit Cloud Native Software Landcscape
- Overcast - Deploy VMs across different cloud providers, and run commands and scripts across any or all of them in parallel via SSH. (SOurce Code)
- Ansible - Provisioning, configuration management, and application-deployment tool
- CFEngine - Configuration management system for automated configuration and maintenance of large-scale computer systems.
- Chef - Configuration management tool using a pure-Ruby, domain-specific language (DSL) for writing system configuration "recipes".
- Puppet - Software configuration management tool which includes its own declarative language to describe system configuration.
- Salt - Event-driven IT automation, remote task execution, and configuration management software.
BSD-3-ClauseJava
BSD-3-ClauseC
Related: DNS - Servers
MITPHP
OLDAP-2.8C
GPL-3.0C
MITGo
GPL-3.0PHP
GPL-2.0Python
GPL-3.0C++
Apache-2.0Shell/PHP/Other
Apache-2.0Java/C++
GPL-2.0C
BSD-2-ClauseC
