| .hecat | ||
| Makefile | ||
- Client management
- DNS - Control Panels
- DNS - Domain Management
- Metrics & Metric Collection
- Newsletters
- Blogs
- Books
- Newsletters
MITRuby
See also: IT Asset Management
Apache-2.0C#/PowerShell
GPL-3.0PHP/Shell
- Ceph - Distributed object store and file system. (Source Code)
- DRBD - Distributed Replicated Block Device. (Source Code)
- GlusterFS - Scale-out network-attached storage file system. (Source Code)
- Kubo - Implementation of IPFS, a global, versioned, peer-to-peer filesystem that seeks to connect all computing devices with the same system of files.
- Hadoop Distributed Filesystem (HDFS) - Distributed, scalable, and portable file-system written in Java for the Hadoop framework. (Source Code)
- JuiceFS - Distributed POSIX file system built on top of Redis and S3. (Source Code)
Apache-2.0Go - LeoFS - Unstructured object/data storage and a highly available, distributed, eventually consistent storage system. (Source Code)
- Lustre - Parallel distributed file system, generally used for large-scale cluster computing. (Source Code)
- OpenAFS - Distributed network file system with read-only replicas and multi-OS support. (Source Code)
- Perkeep - A set of open source formats, protocols, and software for modeling, storing, searching, sharing and synchronizing data (previously Camlistore). (Source Code)
- SheepDog - A distributed Blockdevice, Rest, QEMU and distributed Filesystem storage. (Source Code)
- Openstack Swift - A highly available, distributed, eventually consistent object/blob store. (Source Code)
- TahoeLAFS - secure, decentralized, fault-tolerant, peer-to-peer distributed data store and distributed file system. (Source Code)
- XtreemFS - XtreemFS is a fault-tolerant distributed file system for all storage needs. (Source Code)
BSD-3-ClauseC - PowerDNS Authoritative Server - Versatile nameserver which supports a large number of backends.. (Source Code)
BSD-3-ClauseC
DNS server control panels.
ISCPerl - Pi-hole - A blackhole for Internet qdvertisements with a GUI for management and monitoring. (Source Code)
EUPL-1.2Shell/PHP - Poweradmin - Web-based DNS control panel for PowerDNS server. (Source Code)
GPL-3.0PHP
MITPython
OLDAP-2.8C
GPL-3.0C
See also: Metrics & Metric Collection
See also: Databases, Monitoring
MITGo
GPL-3.0PHP
BSD-2-ClauseCPHP
GPL-2.0C
BSD-2-ClauseC
