| .hecat | ||
| Makefile | ||
- Client management
- Metrics & Metric Collection
- Newsletters
- Remote Desktop Clients
- Blogs
- Books
- Newsletters
MITRuby
AGPL-3.0C/C++
MITLua - HPCBIOS - HPCBIOS is an effort to setup a common, well-documented and reproducible, environment spanning across multiple HPC systems & sites, inclusive of documentation.
- Spack - A flexible package manager that supports multiple versions, configurations, platforms, and compilers. (Source Code)
MIT/Apache-2.0Python
Related: IT Asset Management
Apache-2.0C#/PowerShell
GPL-2.0/OtherPerl/Shell/Other - Fog - Cloning/imaging solution/rescue suite. (Source Code)
GPL-3.0PHP/Shell
GPL-2.0Python - Genesis - A template framework for multi-environment BOSH deployments.
MITPerl - Overcast - Deploy VMs across different cloud providers, and run commands and scripts across any or all of them in parallel via SSH. (Source Code)
Apache-2.0Python
Apache-2.0Python
MITRuby - Fabric - Python library and cli tool for streamlining the use of SSH for application deployment or systems administration tasks. (Source Code)
BSD-2-ClausePython - Mina - Really fast deployer and server automation tool (rake based). (Source Code)
Apache-2.0Python - Vlad the Deployer - Deployment automation (rake based).
MITRuby
MITNodejs/Docker
BSD-3-ClauseJava
BSD-3-ClauseC
Related: DNS - Servers
MITPHP
GLP-3.0JavaScript - ICEcoder - Code editor awesomeness, built with common web languages. (Demo, Source Code)
MITTypeScript
OLDAP-2.8C
Apache-2.0Python - easy-rsa - bash script to build and manage a PKI CA.
AGPL-3.0Python - OpenID Connect - A Simple Identity layer on top of OAuth 2.0.
- Pomerium - An identity and context aware access-proxy inspired by BeyondCorp. (Source Code)
Apache-2.0Docker/Go - Samba – Active Directory and CIFS protocol implementation. (Source Code)
Apache-2.0Go/Docker/K8S
GPL-3.0C
MITGo
GPL-3.0PHP
GPL-2.0Perl - Lewsnetter - E-mail marketing application (create and send e-mail newsletter via SES). Includes subscription management, delivery, bounce and complaint notification, templates, and some stats.
GPL-2.0Python
GPL-3.0C++
GPL-2.0Perl
Apache-2.0Shell/PHP/Other
Apache-2.0Java/C++
GPL-2.0C
- grml – bootable Debian Live CD with powerful CLI tools. (Source Code)
GPL-2.0C
GPL-2.0/LGPL-2.0C - OpenNebula - Flexible enterprise cloud made simple.
- oVirt - Manages virtual machines, storage and virtual networks. (Source Code)
GPL-3.0/CDDL-1.0C++ - XCP-ng - Based on Citrix XenServer, XCP-ng is a fully open source virtualization platform.
- Xen - Virtual machine monitor for 32/64 bit Intel / AMD (IA 64) and PowerPC 970 architectures. (Source Code)
GPL-2.0C
MITGo - ocserv - Cisco AnyConnect-compatible VPN server (Source Code)
- SoftEther - Multi-protocol software VPN with advanced features (Source Code)
GPL-2.0C - WireGuard - Very fast VPN based on elliptic curve and public key crypto.
BSD-2-ClauseC
AGPL-3.0- GNU Affero General Public License 3.0Apache-2.0- Apache, Version 2.0BSD-2-Clause- BSD 2-clause "Simplified"BSD-3-Clause- BSD 3-Clause "New" or "Revised"BUSL-1.1- Business Source License 1.1CDDL-1.0- Common Development and Distribution License 1.0EPL-1.0- Eclipse Public License 1.0GFDL-1.2- GNU Free Documentation License 1.2GPL-2.0- GNU General Public License 2.0GPL-3.0- GNU General Public License 3.0LGPL-2.0- GNU Library General Public License v2 onlyLGPL-2.1- GNU Lesser General Public License v2.1 onlyMIT- MIT LicenseMPL-2.0- Mozilla Public LicenseVim- Vim License
