| .hecat | ||
| Makefile | ||
- Client management
- DNS - Control Panels
- DNS - Domain Management
- Metric & Metric Collection
- Newsletters
- Blogs
- Books
- Newsletters
See also: IT Asset Management
Apache-2.0C#/PowerShell
GPL-3.0PHP/Shell
DNS server control panels.
MITPython
- Apache Directory Server - Extensible and embeddable directory server, certified LDAPv3 compatible, with Kerberos 5 and Change Password Protocol support, triggers, stored procedures, queues and views. (Source Code)
Java - FreeIPA - Integrated security information management solution combining Linux (Fedora), 389 Directory Server, Kerberos, NTP, DNS, and Dogtag Certificate System (web interface and command-line administration tools). (Source Code)
- FreeRADIUS - Multi-protocol policy server (radiusd) that implements RADIUS, DHCP, BFD, and ARP and associated client/PAM library/Apache module.
- lldap - Light (simplified) LDAP implementation with a simple, intuitive web interface and GraphQL support.
GPL-3.0Rust - OpenLDAP - Open-source implementation of the Lightweight Directory Access Protocol (server, libraries and clients).
Collectors only
Dashboards
Storage
GPL-3.0PHP
BSD-2-ClauseCPHP
GPL-2.0C
