- Awesome Sysadmin
- Client Management
- DNS
- Domains
- Metric & Metric Collection
- Newsletter
- NoSQL
- RDBMS
- SSH: see awesome-ssh
- Resources
See also: IT Asset Management
- Web hosting
- DNS
- Server
DNS
Domains
LDAP
- OpenDJ - Fork of OpenDS.
Tools and web interfaces
Single Sign-On (SSO)
- Kratos - Next-gen identity server with Ory-hardened authentication, MFA, FIDO2, profile management, identity schemas, social sign in, registration, account recovery, and IoT auth. Golang, headless, API-only - without templating or theming headaches. (QuickStart, Source Code)
Apache-2.0Golang - PWM - An open source password self-service application for LDAP directories including SSO interfaces (Source Code)
Apache-2.0Java - KeyCloak - Open Source Identity and Access Management (Source Code) Apache-2.0
Java
ApacheGo - checkmk - Comprehensive solution for monitoring of applications, servers, and networks. (Source Code)
Collectors only
Dashboards
Storage
NoSQL
NoSQL databases.
- Column-Family
- Document Store
- Graph
- Key-Value
RDBMS
Relational DBMS.
Resources
Debian-based distributions
RPM-based distributions
Wikis
