| .hecat | ||
| Makefile | ||
- Client management
- DNS - Control Panels
- DNS - Domain Management
- Metric & Metric Collection
- Newsletters
- Blogs
- Books
- Newsletters
See also: IT Asset Management
Apache-2.0C#/PowerShell
GPL-3.0PHP/Shell
DNS server control panels.
MITPython
OLDAP-2.8C
- Fluentd - Log Collector and Shipper. (Source Code)
Apache-2.0Ruby - Flume - Distributed log collection and aggregation system. (Source Code)
MITC - Logstash - Tool for managing events and logs.
Collectors only
Dashboards
Storage
GPL-3.0PHP
BSD-2-ClauseCPHP
GPL-2.0C
