Cabot last commit is dated from Jan 2021. Furthermore its code base is not compatible with Python 3.x and requires Python 2.7. Python 2.7 is unmaintained and does no receive security support since 01 Jan 2020 |
| .hecat | ||
| Makefile | ||
- Client management
- Metrics & Metric Collection
- Newsletters
- Remote Desktop Clients
- Blogs
- Books
- Newsletters
Build automation.
MITRuby
Backup software.
AGPL-3.0C/C++
MIT/Apache-2.0Python
_See also: /r/chatops*
Related: IT Asset Management
Apache-2.0C#/PowerShell
Disk cloning software.
GPL-2.0/OtherPerl/Shell/Other - Fog - Cloning/imaging solution/rescue suite. (Source Code)
GPL-3.0PHP/Shell
GPL-2.0Python - Genesis - A template framework for multi-environment BOSH deployments.
MITPerl - Overcast - Deploy VMs across different cloud providers, and run commands and scripts across any or all of them in parallel via SSH. (Source Code)
Apache-2.0Python
Apache-2.0Python
MITRuby - Fabric - Python library and cli tool for streamlining the use of SSH for application deployment or systems administration tasks. (Source Code)
BSD-2-ClausePython - Mina - Really fast deployer and server automation tool (rake based). (Source Code)
Apache-2.0Python - Vlad the Deployer - Deployment automation (rake based).
MITRuby
MITNodejs/Docker
BSD-3-ClauseJava
BSD-3-ClauseC
Related: DNS - Servers
MITPHP
Open-source code editors.
GLP-3.0JavaScript - ICEcoder - Code editor awesomeness, built with common web languages. (Demo, Source Code)
MITTypeScript
OLDAP-2.8C
Apache-2.0Python - easy-rsa - bash script to build and manage a PKI CA.
Apache-2.0Go/Docker/K8S
IT asset management software.
GPL-3.0C
MPL-2.0C/C++
QPL-1.0PHP - Performance Co-Pilot - Lightweight, distributed system performance and analysis framework. (Source Code)
GPL-2.0C
MITGo
GPL-3.0PHP
GPL-2.0Perl - phpList - Newsletter and email marketing software. (Source Code)
GPL-2.0Python
GPL-3.0C++
GPL-2.0Perl
Apache-2.0Shell/PHP/Other
Apache-2.0Java/C++
GPL-2.0C - LXD - a container "hypervisor" and a better UX for LXC. (Source Code)
GPL-2.0C
Troubleshooting tools.
- grml - bootable Debian Live CD with powerful CLI tools. (Source Code)
GPL-2.0C
Apache-2.0C
GPL-2.0C
GPL-2.0C
BSD-2-ClauseC
AGPL-3.0- GNU Affero General Public License 3.0Apache-2.0- Apache, Version 2.0BSD-2-Clause- BSD 2-clause "Simplified"BSD-3-Clause- BSD 3-Clause "New" or "Revised"BUSL-1.1- Business Source License 1.1CDDL-1.0- Common Development and Distribution License 1.0EPL-1.0- Eclipse Public License 1.0GFDL-1.2- GNU Free Documentation License 1.2GPL-2.0- GNU General Public License 2.0GPL-3.0- GNU General Public License 3.0LGPL-2.0- GNU Library General Public License v2 onlyLGPL-2.1- GNU Lesser General Public License v2.1 onlyMIT- MIT LicenseMPL-2.0- Mozilla Public LicenseNLPL- No Limit Public LicenseQPL-1.0- Q Public License 1.0Vim- Vim License
