| .github/ISSUE_TEMPLATE | ||
| templates | ||
Unraid Templates
- ArchiveBox
- CryptPad
- CyberChef
- Dashmachine
- db-backup
- ddns-route53
- Docpht
- Droppy
- FileRun
- FreePBX
- Freescout
- Firefox-Syncserver
- Flarum
- Golinks
- Gossa
- Gotify
- Homer
- Jitsi
- Kiwix-serve
- Mailpile
- Matrix
- Mattermost
- Miniflux
- Netbox
- phpBB
- PsiTransfer
- Pure-FTPd
- Pwndrop
- Reactive-resume
- Riot-web
- Searx
- Shiori
- StackEdit
- Wallabag
ArchiveBox
Application Name: ArchiveBox
First installation
- After first run shut it down then remove Post Arguments and add
./archive (URL,FEED,BOOKMARK,FILE)https://github.com/pirate/ArchiveBox/wiki/Usage#import-a-single-url-or-list-of-urls-via-stdin - Publishing Your Archive
CryptPad
Application Name: CryptPad
First installation
- Edit config.js /mnt/appdata/cryptpad/cfg/config.js
httpAddress: '0.0.0.0'and remove//before it
CyberChef
Application Name: CyberChef
Dashmachine
Application Name: Dashmachine
Default username and password
- Username:
admin - Password:
admin
Unauthorized
db-backup
Application Name: db-backup
Environment Variables
| Parameter | Description |
COMPRESSION |
Use either Gzip GZ, Bzip2 BZ, XZip XZ, or none NONE - Default GZ |
DB_TYPE |
Type of DB Server to backup couch influx mysql pgsql mongo redis rethink |
DB_HOST |
Server Hostname e.g. mariadb |
DB_NAME |
Schema Name e.g. database |
DB_USER |
username for the database - use root to backup all MySQL of them. |
DB_PASS |
(optional if DB doesn't require it) password for the database |
DB_PORT |
(optional) Set port to connect to DB_HOST. Defaults are provided |
DB_DUMP_FREQ |
How often to do a dump, in minutes. Defaults to 1440 minutes, or once per day. |
DB_DUMP_BEGIN |
What time to do the first dump. Defaults to immediate. Must be in one of two formats |
Absolute HHMM, e.g. 2330 or 0415 |
Relative +MM, i.e. how many minutes after starting the container, e.g. +0 (immediate), +10 (in 10 minutes), or +90 in an hour and a half |
DB_CLEANUP_TIME |
Value in minutes to delete old backups (only fired when dump freqency fires). 1440 would delete anything above 1 day old. You don't need to set this variable if you want to hold onto everything. |
DEBUG_MODE |
If set to true, print copious shell script messages to the container log. Otherwise only basic messages are printed. |
MD5 |
Generate MD5 Sum in Directory, TRUE or FALSE - Default TRUE |
PARALLEL_COMPRESSION |
Use multiple cores when compressing backups TRUE or FALSE - Default TRUE |
SPLIT_DB |
If using root as username and multiple DBs on system, set to TRUE to create Seperate DB Backups instead of all in one. - Default FALSE |
ddns-route53
Before running the docker
- Create ddns-route53.yml file in /mnt/user/appdata/ddns-route53/ - https://github.com/crazy-max/ddns-route53/blob/master/doc/configuration.md
Docpht
Application Name: Docpht
Droppy
Application Name: Droppy
FileRun
Application Name: FileRun
- Username:
superuser - Password:
superuser
FreePBX
Application Name: FreePBX
First installation
- Take time be patient
- Wizard setup go to http://freepbx/admin/config.php
Freescout
Application Name: Freescout
Creating User
- CLI
cd /www/htmlthenphp artisan freescout:create-user
Firefox-Syncserver
Flarum
Application Name: Flarum
Username: flarum
Password: flarum
Notes
- Make Sure the base url is right if it local use only use http://:8000 and if you are hosting it on your domain it should be http://example.com or https://example.com.
Golinks
Application Name: Golinks
Gossa
Application Name: Gossa
Gotify
Application Name: Gotify
mkdir -p /mnt/user/appdata/gotify/config/
wget -O /mnt/user/appdata/gotify/config/config.yml https://raw.githubusercontent.com/gotify/server/master/config.example.yml
- Username:
admin - Password:
admin
Homer
Application Name: Homer
mkdir -p /mnt/user/appdata/homer/config/
wget -O /mnt/user/appdata/homer/config/config.yml https://raw.githubusercontent.com/bastienwirtz/homer/master/config.yml
Jitsi
Application Name: Jitsi
Change appdata location
/mnt/user/appdata/jitsi-web -> /mnt/user/appdata/jitsi/web/
/mnt/user/appdata/jitsi-prosody -> /mnt/user/appdata/jitsi/prosody/
/mnt/user/appdata/jitsi-jvb -> /mnt/user/appdata/jitsi/jvb/
/mnt/user/appdata/jitsi-jicofo -> /mnt/user/appdata/jitsi/jicofo/
Notes
- https://github.com/jitsi/docker-jitsi-meet
- How it all work
Kiwix-serve
Application Name: Kiwix-serve
Notes
- When using variable "DOWNLOAD" remove the link after the download so you don't re-download the same content again
Content
Mailpile
Application Name: Mailpile
Matrix
Application Name: Matrix
Guides
Mattermost
Application Name: Mattermost
Miniflux
Application Name: Miniflux
Notes
- Admin username and password is setup at in docker variables then you can change in Miniflux settings. Docker variable will be ignored when you change it inside the docker.
- PostgreSQL DB Required (Not Included)
Netbox
Application Name: Netbox
Notes
- Create User cli to the docker then
./manage.py createsuperuser - PostgreSQL DB Required (Not Included)
phpBB
Application Name: phpBB
PsiTransfer
Application Name: PsiTransfer
Notes
- Admin Page just add
/adminto your URL
Pure-FTPd
Application Name: Pure-FTPd
Notes
- Creating User use console then
pure-pw useradd admin -u 99 -g 100 -d /home/admin -mthen enter password of your choosing. - https://github.com/crazy-max/docker-pure-ftpd#notes
Pwndrop
Application Name: Pwndrop
Application Site: https://github.com/kgretzky/pwndrop
Github: https://github.com/kgretzky/pwndrop
Reactive-resume
Riot-web
Application Name: Riot-web
mkdir -p /mnt/user/appdata/riot-web/configwget -O /mnt/user/appdata/riot-web/config/config.json https://riot.im/develop/config.json
Searx
Application Name: Searx
Shiori
Application Name: Shiori
Username: shiori
Password: gopher
Notes
- Create new account inside the web gui so the default one will be removed.
StackEdit
Application Name: StackEdit
Wallabag
Application Name: Wallabag
Username: wallabag
Password: wallabag
PHP errors
Missing texture and images
- Make sure the domain variable is right http://ip:6500 and if you are hosting it http://wallabag.example.com or https://wallabag.example.com.
