.github/ISSUE_TEMPLATE | ||
templates | ||
README.md |
Unraid Templates
- Airsonic-advanced
- Apprise
- ArchiveBox
- Backuppc
- Cloudbeaver
- Commento
- CryptPad
- CyberChef
- Dashmachine
- db-backup
- ddns-route53
- Dispatch
- Docpht
- Droppy
- FileRun
- Filestash
- FreePBX
- Freescout
- Firefox-Syncserver
- Flarum
- Golinks
- Gossa
- Gotify
- Healthchecks
- Homer
- Jitsi
- Keycloak
- Kiwix-serve
- Leantime
- Librenms
- Linkding
- Mailpile
- Matomo
- Matrix
- Mattermost
- Mattermost-push-proxy
- Mediagoblin
- Memcached
- Miniflux
- Moodle
- Mumble
- Netbox
- phpBB
- PsiTransfer
- Pterodactyl-panel
- Pterodactyl-daemon
- Pure-FTPd
- Pwndrop
- Quakejs
- Notes
- Reactive-resume
- Redis
- Riot-web
- Searx
- Selfoss
- Shiori
- Shlink
- Shlink-web-client
- Solr
- StackEdit
- Synapse-admin
- Tar1090
- Torprivoxy
- tt-rss
- Wallabag
- Wifi-card
- YaCy
Airsonic-advanced
Apprise
Application Name: Apprise
ArchiveBox
Application Name: ArchiveBox
First installation
- Run the Archivebox Docker and Console to it.
su - archivebox
cd /data
archivebox init
archivebox manage createsuperuser
- Edit Archivebox Docker Click at Advanced View put
server 0.0.0.0:8000
in Post Arguments.
Configuration
Backuppc
Application Name: Backuppc
Cloudbeaver
Application Name: Cloudbeaver
Notes
- There is no appdata https://hub.docker.com/r/dalongrong/cloudbeaver
Commento
Application Name: Commento
Notes
- PostgreSQL DB Required (Not Included)
CryptPad
Application Name: CryptPad
First installation
- Edit /cryptpad/config/config.example.js and rename to /cryptpad/config/config.js
- Map a host port to container port 3000 for web UI
CyberChef
Application Name: CyberChef
Dashmachine
Application Name: Dashmachine
Default username and password
- Username:
admin
- Password:
admin
db-backup
Application Name: db-backup
Environment Variables
Parameter | Description |
COMPRESSION |
Use either Gzip GZ , Bzip2 BZ , XZip XZ , or none NONE - Default GZ |
DB_TYPE |
Type of DB Server to backup couch influx mysql pgsql mongo redis rethink |
DB_HOST |
Server Hostname e.g. mariadb |
DB_NAME |
Schema Name e.g. database |
DB_USER |
username for the database - use root to backup all MySQL of them. |
DB_PASS |
(optional if DB doesn't require it) password for the database |
DB_PORT |
(optional) Set port to connect to DB_HOST. Defaults are provided |
DB_DUMP_FREQ |
How often to do a dump, in minutes. Defaults to 1440 minutes, or once per day. |
DB_DUMP_BEGIN |
What time to do the first dump. Defaults to immediate. Must be in one of two formats |
Absolute HHMM, e.g. 2330 or 0415 |
Relative +MM, i.e. how many minutes after starting the container, e.g. +0 (immediate), +10 (in 10 minutes), or +90 in an hour and a half |
DB_CLEANUP_TIME |
Value in minutes to delete old backups (only fired when dump freqency fires). 1440 would delete anything above 1 day old. You don't need to set this variable if you want to hold onto everything. |
DEBUG_MODE |
If set to true , print copious shell script messages to the container log. Otherwise only basic messages are printed. |
MD5 |
Generate MD5 Sum in Directory, TRUE or FALSE - Default TRUE |
PARALLEL_COMPRESSION |
Use multiple cores when compressing backups TRUE or FALSE - Default TRUE |
SPLIT_DB |
If using root as username and multiple DBs on system, set to TRUE to create Seperate DB Backups instead of all in one. - Default FALSE |
ddns-route53
Before running the docker
- Create ddns-route53.yml file in /mnt/user/appdata/ddns-route53/ - https://github.com/crazy-max/ddns-route53/blob/master/doc/configuration.md
Dispatch
Web-based IRC client in Go.
Application Name: Dispatch
Docpht
Application Name: Docpht
Droppy
Application Name: Droppy
FileRun
Application Name: FileRun
- Username:
superuser
- Password:
superuser
Filestash
Application Name: Filestash
FreePBX
Application Name: FreePBX
First installation
- Take time be patient
- Wizard setup go to http://freepbx/admin/config.php
- Use Database
Freescout
Application Name: Freescout
Creating User
- CLI
cd /www/html
thenphp artisan freescout:create-user
Firefox-Syncserver
Flarum
Application Name: Flarum
Username: flarum
Password: flarum
Notes
- Make Sure the base url is right if it local use only use http://:8000 and if you are hosting it on your domain it should be http://example.com or https://example.com.
Golinks
Application Name: Golinks
Gossa
Application Name: Gossa
Gotify
Application Name: Gotify
mkdir -p /mnt/user/appdata/gotify/config/
wget -O /mnt/user/appdata/gotify/config/config.yml https://raw.githubusercontent.com/gotify/server/master/config.example.yml
- Username:
admin
- Password:
admin
Healthchecks
Homer
Application Name: Homer
mkdir -p /mnt/user/appdata/homer/config/
wget -O /mnt/user/appdata/homer/config/config.yml https://raw.githubusercontent.com/bastienwirtz/homer/master/config.yml
Jitsi
Application Name: Jitsi
Change appdata location
/mnt/user/appdata/jitsi-web
-> /mnt/user/appdata/jitsi/web/
/mnt/user/appdata/jitsi-prosody
-> /mnt/user/appdata/jitsi/prosody/
/mnt/user/appdata/jitsi-jvb
-> /mnt/user/appdata/jitsi/jvb/
/mnt/user/appdata/jitsi-jicofo
-> /mnt/user/appdata/jitsi/jicofo/
Notes
- https://github.com/jitsi/docker-jitsi-meet
- How it all work
Keycloak
Application Name: Keycloak
Kiwix-serve
Application Name: Kiwix-serve
Notes
- When using variable "DOWNLOAD" remove the link after the download so you don't re-download the same content again
Content
Leantime
Application Name: Leantime
First installation
- First setup go to http://leantime/install
Librenms
Application Name: Librenms
Notes
- Database must be CHARACTER SET utf8 COLLATE utf8_unicode_ci
Linkding
Application Name: Linkding
Mailpile
Application Name: Mailpile
Matomo
Application Name: Matomo
Matrix
Application Name: Matrix
Guides
Mattermost
Application Name: Mattermost
Notes
mkdir /mnt/user/appdata/mattermost-push-proxy/config
cd /mnt/user/appdata/mattermost-push-proxy/config
wget https://raw.githubusercontent.com/mattermost/mattermost-push-proxy/master/config/mattermost-push-proxy.json
Mediagoblin
Application Name: Mediagoblin
- Username:
admin
- Password:
admin
Memcached
Application Name: Memcached
Miniflux
Application Name: Miniflux
Moodle
Application Name: Moodle
Notes
- Admin username and password is setup at in docker variables then you can change in Miniflux settings. Docker variable will be ignored when you change it inside the docker.
Mumble
Application Name: Mumble
Notes
- Download config.ini an customize it
wget -O /mnt/user/appdata/mumble/config.ini https://raw.githubusercontent.com/PHLAK/docker-mumble/master/files/config.ini
- See https://wiki.mumble.info/wiki/Murmur.ini for more options
Netbox
Application Name: Netbox
Notes
- Create User cli to the docker then
./manage.py createsuperuser
phpBB
Application Name: phpBB
PsiTransfer
Application Name: PsiTransfer
Notes
- Admin Page just add
/admin
to your URL
Pterodactyl-panel
Creating User
- CLI
cd /www/html
thenphp artisan p:user:make
Pterodactyl-daemon
Application Name: Pterodactyl-daemon
Docker Hub: https://hub.docker.com/r/ccarney16/pterodactyl-daemon/
Pure-FTPd
Application Name: Pure-FTPd
Notes
- Creating User use console then
pure-pw useradd admin -u 99 -g 100 -d /home/admin -m
then enter password of your choosing. - https://github.com/crazy-max/docker-pure-ftpd#notes
Pwndrop
Application Name: Pwndrop
Quakejs
Application Name: Quakejs
Notes
- Use Custom:br0 https://youtu.be/2VnQxxn00jU?t=121 put Fixed IP address
- Copy the ip and access it using you broswer
Reactive-resume
Redis
Application Name: Redis
Riot-web
Application Name: Riot-web
mkdir -p /mnt/user/appdata/riot-web/config
wget -O /mnt/user/appdata/riot-web/config/config.json https://riot.im/develop/config.json
Searx
Application Name: Searx
Selfoss
Application Name: Selfoss
Shiori
Application Name: Shiori
Username: shiori
Password: gopher
Notes
- Create new account inside the web gui so the default one will be removed.
Shlink
Application Name: Shlink
Shlink-web-client
Before Installing
- Install shlink
- CLI to it and enter "shlink api-key:generate"
- Copy the api and add and edit to servers.json
- https://hub.docker.com/r/shlinkio/shlink-web-client/ servers.json
Solr
Application Name: Solr
StackEdit
Application Name: StackEdit
Synapse-admin
Icons made by Vitaly Gorbachev from www.flaticon.com Application Name: Synapse-admin
Tar1090
Icons made by Smashicons from www.flaticon.com Application Name: Synapse-admin
Torprivoxy
Icons made by photo3idea_studio from www.flaticon.com Application Name: Synapse-admin
tt-rss
Wallabag
Application Name: Wallabag
Username: wallabag
Password: wallabag
PHP errors
Missing texture and images
- Make sure the domain variable is right http://ip:6500 and if you are hosting it http://wallabag.example.com or https://wallabag.example.com.
Wifi-card
YaCy
Application Name: YaCy
Username: admin
Password: docker
Notes
Set an admin account immediately after the first start-up. Open:
http://:8090/ConfigAccounts_p.html
^back to top^
