Unraid Docker Templates
2020-05-23 23:11:34 +03:00
.github/ISSUE_TEMPLATE Update issue templates 2020-04-19 18:50:46 +03:00
templates Update keycloak.xml 2020-05-23 23:11:34 +03:00
README.md added templates 2020-05-19 23:46:57 +03:00
Unraid Templates
ArchiveBox
ArchiveBox
Application Name: ArchiveBox
First installation
Backuppc
Backuppc
Application Name: Backuppc
CryptPad
CryptPad
Application Name: CryptPad
First installation
  • Edit config.js /mnt/appdata/cryptpad/cfg/config.js httpAddress: '0.0.0.0' and remove // before it
CyberChef
CyberChef
Application Name: CyberChef
Dashmachine
Dashmachine
Application Name: Dashmachine
Default username and password
  • Username: admin
  • Password: admin
Unauthorized
db-backup
db-backup
Application Name: db-backup
Environment Variables
Parameter Description
ddns-route53
ddns-route53
Before running the docker
Dispatch
Dispatch
Application Name: Dispatch
Docpht
Docpht
Application Name: Docpht
Droppy
Droppy
Application Name: Droppy
FileRun
FileRun
Application Name: FileRun
  • Username: superuser
  • Password: superuser
Filestash
Filestash
Application Name: Filestash
FreePBX
FreePBX
Application Name: FreePBX
First installation
Freescout
freescout
Application Name: Freescout
Creating User
Firefox-Syncserver
Firefox-Syncserver
Flarum
Flarum
Application Name: Flarum
Notes
Golinks
Golinks
Application Name: Golinks
Gossa
Gossa
Application Name: Gossa
Gotify
Gotify
Application Name: Gotify
  • Username: admin
  • Password: admin
Homer
Homer
Application Name: Homer
mkdir -p /mnt/user/appdata/homer/config/ wget -O /mnt/user/appdata/homer/config/config.yml https://raw.githubusercontent.com/bastienwirtz/homer/master/config.yml
Jitsi
Jitsi
Application Name: Jitsi
Change appdata location
Notes
Keycloak
Keycloak
Application Name: Keycloak
Kiwix-serve
Kiwix-serve
Application Name: Kiwix-serve
Notes
Content
Leantime
Leantime
Application Name: Leantime
First installation
Linkding
Linkding
Application Name: Linkding
Mailpile
Mailpile
Application Name: Mailpile
Matomo
Mailpile
Application Name: Matomo
Matrix
Matrix
Application Name: Matrix
Guides
Mattermost
Mattermost
Application Name: Mattermost
Mediagoblin
Mediagoblin
Application Name: Mediagoblin
  • Username: admin
  • Password: admin
Miniflux
Miniflux
Application Name: Miniflux
Moodle
Moodle
Application Name: Moodle
Notes
Mumble
Mumble
Application Name: Mumble
Notes
Netbox
Netbox
Application Name: Netbox
Notes
phpBB
phpBB
Application Name: phpBB
PsiTransfer
psitransfer
Application Name: PsiTransfer
Notes
Pterodactyl-panel
pterodactyl-panel
Creating User
Pure-FTPd
Pure-FTPd
Application Name: Pure-FTPd
Notes
Pwndrop
Pwndrop
Application Name: Pwndrop
Quakejs
Quakejs
Application Name: Quakejs
Notes
Reactive-resume
Reactive-resume
Redis
Redis
Application Name: Redis
Riot-web
Riot-web
Application Name: Riot-web
Searx
Searx
Application Name: Searx
Selfoss
Selfoss
Application Name: Selfoss
Shiori
Shiori
Application Name: Shiori
Notes
Solr
Solr
Application Name: Solr
StackEdit
Shiori
Application Name: StackEdit
Wallabag
Wallabag
Application Name: Wallabag
PHP errors
Missing texture and images
YaCy
YaCy
Application Name: YaCy
