Unraid Docker Templates
2022-10-29 15:23:24 +03:00
.github/ISSUE_TEMPLATE Delete docker-template-request.md 2022-01-07 08:55:59 +03:00
templates Create nut.xml 2022-10-29 15:23:24 +03:00
README.md Update README.md 2022-10-29 15:22:40 +03:00
Unraid Templates
Airsonic-advanced
Airsonic-advanced
^back to top^
Apprise
Apprise
Application Name: Apprise
^back to top^
ArchiveBox
ArchiveBox
Application Name: ArchiveBox
First installation
Configuration
^back to top^
Backuppc
Backuppc
Application Name: Backuppc
^back to top^
Blueiris
Blueiris
Application Name: Blueiris
^back to top^
Changedetection.io
Changedetection.io
^back to top^
Cloudbeaver
Cloudbeaver
Application Name: Cloudbeaver
Notes
^back to top^
Commento
Commento
Application Name: Commento
Notes
^back to top^
Crypto-exchanges-gateway
^back to top^
CryptPad
CryptPad
Application Name: CryptPad
^back to top^
First installation
CyberChef
CyberChef
Application Name: CyberChef
^back to top^
Dashmachine
Dashmachine
Application Name: Dashmachine
Default username and password
  • Username: admin
  • Password: admin
^back to top^
db-backup
db-backup
Application Name: db-backup
Environment Variables
Parameter Description
^back to top^
ddns-route53
ddns-route53
Before running the docker
^back to top^
Dispatch
Dispatch
Web-based IRC client in Go.
Application Name: Dispatch
^back to top^
Docpht
Docpht
Application Name: Docpht
^back to top^
Droppy
Droppy
Application Name: Droppy
^back to top^
ecoDMS
ecoDMS
Application Name: ecoDMS
^back to top^
FileRun
FileRun
Application Name: FileRun
Docker Hub: https://hub.docker.com/r/filerun/filerun/
  • Username: superuser
  • Password: superuser
^back to top^
Element-web
Element-web
Application Name: Element-web
^back to top^
Epicgames-freegames
Epicgames-freegames
^back to top^
Filestash
Filestash
Application Name: Filestash
^back to top^
Firefox-Syncserver
Firefox-Syncserver
^back to top^
Flarum
Flarum
Application Name: Flarum
Notes
^back to top^
FreePBX
FreePBX
Application Name: FreePBX
First installation
^back to top^
Freescout
freescout
Application Name: Freescout
Creating User
^back to top^
Golinks
Golinks
Application Name: Golinks
^back to top^
Gossa
Gossa
Application Name: Gossa
^back to top^
Gotify
Gotify
Application Name: Gotify
  • Username: admin
  • Password: admin
^back to top^
Healthchecks
Healthchecks
^back to top^
Homer
Homer
Application Name: Homer
^back to top^
Jitsi
Jitsi
Application Name: Jitsi
Change appdata location
Notes
^back to top^
Keycloak
Keycloak
Application Name: Keycloak
^back to top^
Kiwix-serve
Kiwix-serve
Application Name: Kiwix-serve
Notes
Content
^back to top^
Leantime
Leantime
Application Name: Leantime
First installation
^back to top^
Librenms
Librenms
Application Name: Librenms
Notes
^back to top^
Linkace
Linkace
Application Name: Linkace
^back to top^
Linkding
Linkding
Application Name: Linkding
^back to top^
Mailpile
Mailpile
Application Name: Mailpile
^back to top^
Matomo
Mailpile
Application Name: Matomo
^back to top^
Matrix
Matrix
Application Name: Matrix
Guides
^back to top^
Mattermost
Mattermost
Application Name: Mattermost
^back to top^
Mattermost-push-proxy
Notes
^back to top^
Mediagoblin
Mediagoblin
Application Name: Mediagoblin
  • Username: admin
  • Password: admin
^back to top^
Memcached
Memcached
Application Name: Memcached
^back to top^
Miniflux
Miniflux
Application Name: Miniflux
^back to top^
Moodle
Moodle
Application Name: Moodle
Notes
^back to top^
Mumble
Mumble
Application Name: Mumble
Notes
^back to top^
Netbox
Netbox
Application Name: Netbox
Notes
^back to top^
Nut
Nut
Squirrel icons created by Freepik - Flaticon
Application Name: Nut
Application Site: https://github.com/shawly/docker-nut
Docker Hub: https://hub.docker.com/r/shawly/nut
Github: https://github.com/shawly/docker-nut
^back to top^
phpBB
phpBB
Application Name: phpBB
^back to top^
PsiTransfer
psitransfer
Application Name: PsiTransfer
Notes
^back to top^
Pterodactyl-panel
pterodactyl-panel
Creating User
^back to top^
Pure-FTPd
Pure-FTPd
Application Name: Pure-FTPd
Notes
^back to top^
Pwndrop
Pwndrop
Application Name: Pwndrop
^back to top^
Quakejs
Quakejs
Application Name: Quakejs
Notes
^back to top^
Reactive-resume
Reactive-resume
^back to top^
Redis
Redis
Application Name: Redis
^back to top^
Riot-web
Riot-web
Application Name: Riot-web
^back to top^
Searx
Searx
Application Name: Searx
^back to top^
Selfoss
Selfoss
Application Name: Selfoss
^back to top^
Send
Send
Application Name: Send
^back to top^
Shaarli
Shaarli
Application Name: Shaarli
^back to top^
Shiori
Shiori
Application Name: Shiori
Notes
^back to top^
Shlink
Shlink
Application Name: Shlink
^back to top^
Shlink-web-client
Shlink-web-client
Before Installing
  1. Install shlink
^back to top^
Solr
Solr
Application Name: Solr
^back to top^
StackEdit
Shiori
Application Name: StackEdit
^back to top^
Synapse-admin
Synapse-admin
Synapse admin ui
^back to top^
Tar1090
Tar1090
^back to top^
Torprivoxy
Torprivoxy
^back to top^
tt-rss
tt-rss
^back to top^
Wallabag
Wallabag
Application Name: Wallabag
PHP errors
Missing texture and images
^back to top^
Weechat
Weechat
^back to top^
Wifi-card
Wifi-card
Application Name: Wifi-card
^back to top^
YaCy
YaCy
Application Name: YaCy
Notes
