This repository provides configuration and instructions for how to get started with Drone CI
drone-quickstart
This repository provides configuration and instructions for how to get started with Drone CI from Harness
- Comfortable running commands in the terminal
- A GitHub account
- A ngrok account
- A computer that can run amd64 or arm64 Docker containers (this includes the new M1-based Macs)
- In your terminal, verify you have
dockeranddocker-composecommands available
Tools used
- Docker - for running the Drone and Drone Docker Runner processes
- ngrok - creates a tunnel between your local Drone docker container and the outside world, allowing it to receive webhooks from GitHub
Steps
Create the tunnel
- Login to https://ngrok.com
- Open https://dashboard.ngrok.com/get-started/setup, follow the steps to install the ngrok binary and connect to your account
- Create the tunnel by running
ngrok http 8080in your terminal, do not stop the process until you are finished with this guide ngrokwill create your tunnel and provide you with a URL such ashttps://abcd-3fg-hij-k1-mn.ngrok.io, make a note of it
Create the GitHub OAuth Application
- Follow Drone's Create an OAuth Application documentation
- For the "Homepage URL", enter the
ngrokURL from the previous step - For the "Authorization callback URL", enter the same
ngrokURL, with/loginappended - You will be given the "Client ID" and a "Client secret", make a note of each (the secret is only displayed once, if you misplace it, you will need to generate a new client secret)
Start the Drone and Drone Runner processes
- Fork this repository and clone the fork to your computer
- Edit the file
run.sh
- Set
DRONE_GITHUB_CLIENT_IDandDRONE_GITHUB_CLIENT_SECRETusing the "Client ID" and "Client secret" from the previous step - Set
DRONE_GITHUB_ADMINto your GitHub username - Set
DRONE_SERVER_HOSTto yourngrokURL, without thehttps://(if yourngrokURL ishttps://abcd-3fg-hij-k1-mn.ngrok.io, setDRONE_SERVER_HOSTtoabcd-3fg-hij-k1-mn.ngrok.io) - Save your changes
- Open a new terminal session and change to the directory where you checked out this repository
- Execute
run.shby typing./run.shand hitting enter - Open your
ngrokURL in a browser, you should be greeted with "Welcome to Drone"! 🎉
Activate your repository
- Click "Continue", you will be prompted to authorize your OAuth application in your GitHub account
- Next you should see the dashboard, if you do not see any repositories, click the "Sync" button
- Your forked repository should now appear in the list, click the repository and then click "Activate Repository"
