Has anyone tried 2.5.x with the supplicant method? #22
Closed
opened 2020-08-19 10:11:06 +05:30 by bigjohns97 · 5 comments
bigjohns97 commented 2020-08-19 10:11:06 +05:30 (Migrated from github.com)
Just wondering if anyone has tried the 2.5.x version of PfSense with the supplicant method, thinking of trying it out this weekend.
MonkWho commented 2020-08-24 23:59:41 +05:30 (Migrated from github.com)
Pfatt scripts have not been tested on pfsense 2.5.x. If you do end up testing please let us know if you encounter any issues.
bigjohns97 commented 2020-08-25 00:03:38 +05:30 (Migrated from github.com)
I ended up upgrading and haven't come across any issues yet.
MonkWho commented 2020-08-25 00:13:03 +05:30 (Migrated from github.com)
Excellent news. Are you using a traditional bypass with your RG still hooked up or are you using a supplicant method?
bigjohns97 commented 2020-08-25 00:15:30 +05:30 (Migrated from github.com)
Supplicant, kernel module was already present.
Original install was from a 2.4.5 - updated to p1 through GUI, and then to 2.5.0 through GUI as well.
PfblockerNG did require a uninstall and reinstall but everything else worked out of the box. I am running a beta version of pfb
Supplicant, kernel module was already present. Original install was from a 2.4.5 - updated to p1 through GUI, and then to 2.5.0 through GUI as well. PfblockerNG did require a uninstall and reinstall but everything else worked out of the box. *I am running a beta version of pfb*
MonkWho commented 2020-08-25 00:21:25 +05:30 (Migrated from github.com)
Perfect. Thank you for providing additional details.
No milestone
No project
No assignees
1 participant
Notifications
Due date
No due date set.
No dependencies set.
Reference: hhf/pfatt#22
No description provided.
