Request more noob friendly instruction for ipv6 Prefix Delegation #29
Labels
No milestone
No project
No assignees
1 participant
Notifications
Due date
No due date set.
No dependencies set.
Reference: hhf/pfatt#29
Loading…
Reference in a new issue
No description provided.
Delete branch "%!s()"
Under the IPV6 Section it has
Go to Services > DHCPv6 Server & RA
Enable DHCPv6 server on interface LAN
Configure a range of ::0001 to ::ffff:ffff:ffff:fffe
Configure a Prefix Delegation Range to 64
Save
Go to the Router Advertisements tab
Configure Router mode as Stateless DHCP
Save
The part I just literally cannot understand is the
Would It be possible to just add the From and To Values to the guide?
Have you tried leaving
Prefix Delegation Rangeblank and settingPrefix Delegation Sizeto 64? That is how mine is set up, but looking back not because I understood the directions. I suppose that was a mistake that I made, but my config works... It might be just supposed to sayPrefix Delegation Sizein the instructions. Can anyone else weigh in on this?edit: it looks like
Prefix Delegation Rangeisn't necessary unless you would like to delegate prefixes to the LAN, and for a home router you probably just want to serve out addresses. I am quite certain that the README should sayPrefix Delegation Size.https://forum.netgate.com/topic/113550/solved-lan-ipv6-clients-not-getting-pfsense-lan-ipv6-tracked-ip-for-dnsforward/9
Wow, i never tried to just leave it blank. That would of helped me not bang my head against the wall for hours.
Thank you for putting together a pull request @AndrewReaganM. Hope this helps more people configure their IPv6 stuff.
