Struggling after 2.5 upgrade #51
Labels
No milestone
No project
No assignees
1 participant
Notifications
Due date
No due date set.
No dependencies set.
Reference: hhf/pfatt#51
Loading…
Reference in a new issue
No description provided.
Delete branch "%!s()"
I had this working in bypass mode for more than a year previously, but after upgrading to 2.5 I've been unable to get it working again on a couple occasions. There's only so much time I can spend debugging with the internet down. 😬 Hoping someone here can help since everything seems set up correctly, but EAP simply fails to authenticate. I'm currently running in IP passthrough on the gateway (BGW210).
Setup:
em0is ONTem1is LANem2is unusedem3is RGnetgraph
I should have opened multiple terminals to dump the interfaces simultaneously for a clearer picture, but I think this gets the point across. The behavior seen below is exactly what happens in a ~30s loop. Of note - I don't know where this Thompson Telecom MAC address (
00:90:d0:<snip>) is coming from since all of the NICs are Intel and there's nothing with that MAC in the path that I can tell (though I don't know the ONT's MAC).RG
ONT
ngeth0
pfatt.sh logs
(prefix removed for brevity)
Any help or similar experiences would be greatly appreciated! I'm kind of at a loss as to why it's not working, but also not 100% sure on exactly what traffic should or should not be tagged
vlan 0(primarily in regards to EAP).I think because you have eapol start to the RG you actually authenticated and are failing to get a dhcp address. There is a similar reddit post, unless this is your post. https://www.reddit.com/r/PFSENSE/comments/lw9uhl/att_fiber_pfatt_pfsense_25_dhcp_not_getting_ip_on
@Frick I'm the author of the reddit post @septer012 linked above. As per my post, I had issues for weeks that I could not resolve. The eapol is successful, looks like yours is as well, but the router never gets the DHCP IP for some reason. I have no clue why.
I could only resolve the issue by going to pfSense 2.4.5. Since then my system have been running stable for more than 2 weeks.
Sorry for the radio silence. I've been incredibly busy with some other things. I'll give this a shot again in a couple of weeks. I'm traveling a bit right now and really love the Wireguard integration with pfSense 2.5 and so unwilling to downgrade to 2.4.5 for now. Really hoping to figure this out since I'm otherwise very happy with 2.5!
You must have been busy to miss the post-release pfSense 2.5/wireguard back and forth. Long story - short version is that there are critical bugs in the pfSense wireguard version and it will be removed in 2.5.1.
https://arstechnica.com/gadgets/2021/03/buffer-overruns-license-violations-and-bad-code-freebsd-13s-close-call/
I really was. That is awful news, but thank you for bringing it to my attention. I'll spend my next opportunity downgrading to 2.4.5 and also looking for something else to get my Wireguard fix, whether just a Pi behind pfSense or replacing pfSense all together. 😞
You can Try OPNsense. Similar setup to pfSense, but better GUI, IMO. Running it in a VM now. Works with this AT&T bypass script and has a safe wireguard implementation, not quite as fast as a kernel implementation, but still faster than openVPN and the same setup.
Can confirm, having this exact same issue. Cannot get a DHCP lease to save my life. This worked perfectly in 2.4.5.
Same issue here.
Apparently working on 2.5.1. https://www.reddit.com/r/PFSENSE/comments/mrnuno/pfsense_ce_251_and_pfatt
I rolled the dice. It took a long time after upgrade to boot up, but its working and I got an IP address.
21.02.2-RELEASE (amd64)
