2.4.5 and ng_etf on ARM processors #6
Closed
opened 2020-05-12 22:04:08 +05:30 by tyler-8 · 3 comments
tyler-8 commented 2020-05-12 22:04:08 +05:30 (Migrated from github.com)
Per this issue https://redmine.pfsense.org/issues/10463 - ng_etf is not available to pfSense running on ARM processors. 2.4.5-p1 is when it will be fixed. Until then, you'll have to build that module for yourself using the 'legacy' way.
MonkWho commented 2020-05-12 22:32:34 +05:30 (Migrated from github.com)
Oh yeah I forgot to add the note to the readme to mention it. Thank you for catching it.
Prodian0013 commented 2020-05-13 06:09:30 +05:30 (Migrated from github.com)
@tyler-8 so after 2.4.5-p1 pfatt should all work with the Netgate SG-1100? I dont have one just been looking at getting one but only if pfatt method works with it.
MonkWho commented 2020-05-13 06:30:52 +05:30 (Migrated from github.com)
@Prodian0013 currently according to that bug report they are planning to add ng_etf in 2.4.5-p1. Unfortunately it's not guaranteed so we can't say for sure. Once it's added you should be able to run this bypass on any hardware and not just amd64 architecture based ones.
If you want it now you can look into running a VM of FreeBSD 11.3 and copying ng_etf it from there.
@Prodian0013 currently according to that bug report they are planning to add ng_etf in 2.4.5-p1. Unfortunately it's not guaranteed so we can't say for sure. Once it's added you should be able to run this bypass on any hardware and not just amd64 architecture based ones. If you want it now you can look into running a VM of FreeBSD 11.3 and copying ng_etf it from there.
No milestone
No project
No assignees
1 participant
Notifications
Due date
No due date set.
No dependencies set.
Reference: hhf/pfatt#6
No description provided.
