Need ng_etf.ko from BSD 12 to complete upgrade from 2.4.5 to 2.5.2 #62
Open
opened 2021-11-21 21:06:25 +05:30 by TopBanana123 · 0 comments
TopBanana123 commented 2021-11-21 21:06:25 +05:30 (Migrated from github.com)
Is anyone able to help with a copy of the correct file?
I installed pfatt a long time ago from the old repo, and ng_etf.ko was included and I copied it into pfsense
It looks like in this repo the file is no longer there, and since I now have a BSD 11 version of ng_etf.ko, pfatt does not work. On boot I get interface mismatch and I can't see netgraph
Are we able to add in the new version of ng_etf.ko to the repo for those upgrading from 2.4.5 to 2.5.2?
Thanks
Is anyone able to help with a copy of the correct file? I installed pfatt a long time ago from the old repo, and ng_etf.ko was included and I copied it into pfsense It looks like in this repo the file is no longer there, and since I now have a BSD 11 version of ng_etf.ko, pfatt does not work. On boot I get interface mismatch and I can't see netgraph Are we able to add in the new version of ng_etf.ko to the repo for those upgrading from 2.4.5 to 2.5.2? Thanks
No milestone
No project
No assignees
1 participant
Notifications
Due date
No due date set.
No dependencies set.
Reference: hhf/pfatt#62
No description provided.
