Extremely Slow Speeds with FW4B #63
Labels
No milestone
No project
No assignees
1 participant
Notifications
Due date
No due date set.
No dependencies set.
Reference: hhf/pfatt#63
Loading…
Reference in a new issue
No description provided.
Delete branch "%!s()"
I am looking to see if there is a known issue with speed drops once using the bypass method, or maybe it is caused by using the 5268AC? I just got the Protectli FW4B and have been using 2.4.5p1 due to not being able to get it working with 2.5. I have been running "successfully" for about 4 weeks now. However, I have tried multiple fresh installations with nothing except the required stuff to make pfatt work. I get the following speeds no matter what I have tried:
Only on RG:
~950up/~940down
Using pfatt:
~160-350up/~150down
Am I missing something? I tried swapping the ethernet cable as I heard that caused it for one person, but that didn't help me. Would buying a NVG599 from ebay and getting the certs fix this? I am assuming it must not happen very often as there is only like two reddit posts and zero issues on here.
Thanks for your help!
I have basically the same or similar issue. I reproduced it with both opnsense and pfsense 2.5.2.
Both opn and pfsense will get full (+900mbps) speeds without pfatt while running behind my old 2.4.5 pfsense installation. Once I put pfatt on 2.5.2 and move it to be the primary firewall it drops the download speeds to ~500mbps down and ~900mbps up (when using the speedtest app multiconnection test).
My RG is a 5268, but I'm not yet using those scripts.
in-place upgraded from 2.4.5 on an Dell SFF w/o issue, could be a bug with the Protectli, never liked those units (I had a fleet of like 100, they all underperformed an old dell with an i5)
speeds 940/940
