Updated README for OPNsense #72
No reviewers
Labels
No milestone
No project
No assignees
1 participant
Notifications
Due date
No due date set.
No dependencies set.
Reference: hhf/pfatt#72
Loading…
Reference in a new issue
No description provided.
Delete branch "StanESmith/supplicant_OPNsense_testing"
Updated the README for OPNsense branch, cleaned up the relevant information and took out the info that pertained to Pfsense if it wasn't applicable to OPNsense.
Any reason for removal of supplicant method and certificate extraction from README? It works perfectly fine with OPNsense for me.
Hmm I didn’t remove them on purpose. I’ll check back tonight to try and clean it back up and add them back in. My intention was to cleanup the README and change out anything related to Pfsense for the things only needed for OPNsense.
I've added those sections back. Hopefully the original author comes back around to merge the changes.
