ACME Client cron Job Causes Loss of WAN Connectivity #76
Open
opened 2022-06-02 12:33:09 +05:30 by owenthewizard · 4 comments
owenthewizard commented 2022-06-02 12:33:09 +05:30 (Migrated from github.com)
No description provided.
Your-New-SJW-Waifu commented 2022-09-09 01:52:25 +05:30 (Migrated from github.com)
Can you describe exactly what type of verification, what CA, etc. you're using?
I use ZeroSSL with DNS verification and I haven't experienced this issue.
This sounds more like an issue with the plugin rather than an issue with this project.
Can you describe exactly what type of verification, what CA, etc. you're using? I use ZeroSSL with DNS verification and I haven't experienced this issue. This sounds more like an issue with the plugin rather than an issue with this project.
owenthewizard commented 2022-09-10 21:18:59 +05:30 (Migrated from github.com)
Let's Encrypt with both HTTP-01 and DNS-01 challenges caused the issue for me. Also using the automation restart OPNsense Web UI.
Mtbred commented 2022-11-29 12:37:09 +05:30 (Migrated from github.com)
We're you ever able to find anything else around this/restore functionality after enabling acme cron job @owenthewizard? I'm experiencing similar.
Particularly, my WAN interface no longer appears to pull an IP from dhcp. /var/log/pfatt.log appears exactly the same as before the addition of of the acme package and cron job.Is there any other logs that I could grab which would be helpful here?
We're you ever able to find anything else around this/restore functionality after enabling acme cron job @owenthewizard? I'm experiencing similar. Particularly, my WAN interface no longer appears to pull an IP from dhcp. /var/log/pfatt.log appears exactly the same as before the addition of of the acme package and cron job.Is there any other logs that I could grab which would be helpful here?
owenthewizard commented 2022-12-03 21:04:31 +05:30 (Migrated from github.com)
Nope, I just have the cron job disabled. No leads on the cause or resolution.
> We're you ever able to find anything else around this/restore functionality after enabling acme cron job @owenthewizard? I'm experiencing similar. Particularly, my WAN interface no longer appears to pull an IP from dhcp. /var/log/pfatt.log appears exactly the same as before the addition of of the acme package and cron job.Is there any other logs that I could grab which would be helpful here? Nope, I just have the cron job disabled. No leads on the cause or resolution.
No milestone
No project
No assignees
1 participant
Notifications
Due date
No due date set.
No dependencies set.
Reference: hhf/pfatt#76
