Enhancement - speed up booting #80
Labels
No milestone
No project
No assignees
1 participant
Notifications
Due date
No due date set.
No dependencies set.
Reference: hhf/pfatt#80
Loading…
Reference in a new issue
No description provided.
Delete branch "%!s()"
This applies to either of the *sense flavors.
In the script, in the following section;
immediately under the last line (after waiting for EAP...), add the following
I observed in testing that the ont sends out a "username......." request about every 30 seconds. Depending on timing, this may extend the boot up process by that long. By issuing the login command, it jumpstarts the eapol auth process almost immediately. The sleep 5 is there to allow the system time to bring up the interface.
Nice, adding this to owenthewizard/opnatt.
