"sh: /conf/pfatt/bin/pfatt.sh: Permission denied" on pfSense 2.6 w/ ZFS #81
Labels
No milestone
No project
No assignees
1 participant
Notifications
Due date
No due date set.
No dependencies set.
Reference: hhf/pfatt#81
Loading…
Reference in a new issue
No description provided.
Delete branch "%!s()"
Not sure if this is an issue, or just something I’m doing wrong. I’m fairly new to pfSense and a lot of this is over my head.
I installed pfSense 2.6 on a Protectli Vault and selected ZFS for the filesystem. I followed the bridge method instructions from the supplicant branch, but couldn’t get it working, so I tried the master branch, and it worked fine. Then I decided try the supplicant method with certificates.
During bootup, I kept getting:
sh: /conf/pfatt/bin/pfatt.sh: Permission deniedMy file permissions, showed:
-rwxr-xr-x 1 root wheel 9194 Apr 5 14:18 pfatt.shSince I couldn’t get it working, I moved
pfatt.shto/root/binand left the certs in/conf/pfatt/wpa. I rebooted and everything worked as expected.There’s a Netgate forum post (see Apr 26, 2022, 6:03PM & Jul 21, 2022, 4:24 PM) which discusses a similar permissions issue. They mention
/confbeing locked down and a Netgate admin says to use/rootinstead. That led me to trymount -p, which shows:pfSense/cf/conf /cf/conf zfs rw,noexec,nosuid,noatime,nfsv4acls 0I’m assuming
noexecon thepfSense/cf/confline meanspfatt.shcan’t run in the/confdirectory. Does this sound correct? If so, any issue with leavingpfatt.shin/root/bin? Thanks.Correct
No issue, just make sure you have the correct path(s) when calling the script, certificates, etc.
Is there a particular reason why /conf was chosen as the folder for the pfatt.* scripts in the first place? I recall this being used way back - 3+ years ago when the script first came about.
Thanks!
To be honest I'm not familiar enough with pfSense to know.
