How to run gen-duid.sh #84
Open
opened 2023-06-08 05:41:08 +05:30 by Cmillets · 1 comment
Cmillets commented 2023-06-08 05:41:08 +05:30 (Migrated from github.com)
I have an AT&T pace 5268ac Gateway and I'm attempting to setup IPv6. I feel silly asking this.....how/where do I run [gen-duid.sh].
aholmes55 commented 2023-06-10 19:22:00 +05:30 (Migrated from github.com)
I found the guid script doesn't generate the whole Identifier. This html/javascript seems to do it correctly. Select Pace and put in your serial number from the sticker on your 5268ac. Change the extension of this from .txt to .html and open in the browser of your choice.
GW DUID Generator.txt
I found the guid script doesn't generate the whole Identifier. This html/javascript seems to do it correctly. Select Pace and put in your serial number from the sticker on your 5268ac. Change the extension of this from .txt to .html and open in the browser of your choice. [GW DUID Generator.txt](https://github.com/MonkWho/pfatt/files/11712553/GW.DUID.Generator.txt)
No milestone
No project
No assignees
1 participant
Notifications
Due date
No due date set.
No dependencies set.
Reference: hhf/pfatt#84
No description provided.
