Updated instructions #86
Open
opened 2023-07-05 04:52:38 +05:30 by uchagani · 2 comments
uchagani commented 2023-07-05 04:52:38 +05:30 (Migrated from github.com)
Do the instructions on the Readme still work with the new versions of Pfsense that has everything built in? I'm using intel nics.
altodd commented 2024-02-19 05:07:06 +05:30 (Migrated from github.com)
Any luck? So far I'm getting stuck with the script failing on defining etf.
tehdango commented 2024-02-19 08:46:27 +05:30 (Migrated from github.com)
If you want to do the bridged mode you can now use the built in pfsense method but I believe you need the plus edition:
https://docs.netgate.com/pfsense/en/latest/recipes/authbridge.html
The wpa supplicant method works still but its all native to pfsense as well. Check this thread out:
https://github.com/MonkWho/pfatt/pull/73
If you want to do the bridged mode you can now use the built in pfsense method but I believe you need the plus edition: [https://docs.netgate.com/pfsense/en/latest/recipes/authbridge.html](url) The wpa supplicant method works still but its all native to pfsense as well. Check this thread out: [https://github.com/MonkWho/pfatt/pull/73](url)
No milestone
No project
No assignees
1 participant
Notifications
Due date
No due date set.
No dependencies set.
Reference: hhf/pfatt#86
No description provided.
