| bin | ||
| img | ||
- Once the authentication completes, you'll be to properly "talk" to the outside. But strangely, all of your traffic will need to be tagged with VLAN id 0 before the IP gateway will respond. I believe VLAN0 is an obscure Cisco feature of 802.1Q CoS, but I'm not really sure.
Copy the
bin/ng_etf.koamd64 kernel module to/boot/kernelon your pfSense box (because it isn't included):a) Use the pre-compiled kernel module from me, a random internet stranger:
scp bin/ng_etf.ko root@pfsense:/boot/kernel/ ssh root@pfsense chmod 555 /boot/kernel/ng_etf.koNOTE: The
ng_etf.koin this repo was compiled for amd64 from the FreeBSD 11.2 release source code. It may also work on other/future versions of pfSense depending if there have been significant changes.b) Or you, a responsible sysadmin, can compile the module yourself from another, trusted FreeBSD machine. You cannot build packages directly on pfSense. Your FreeBSD version should match that of your pfSense version. (Example: pfSense 2.4.4 = FreeBSD 11.2)
# from a FreeBSD machine (not pfSense!) fetch ftp://ftp.freebsd.org/pub/FreeBSD/releases/amd64/amd64/11.2-RELEASE/src.txz tar -C / -zxvf src.txz cd /usr/src/sys/modules/netgraph make scp etf/ng_etf.ko root@pfsense:/boot/kernel/ ssh root@pfsense chmod 555 /boot/kernel/ng_etf.koNOTE: You'll need to tweak your compiler parameters if you need to build for another architecture, like ARM.
bin/pfatt.shas noted below.$RG_ETHER_ADDRshould match the MAC address of your Residential Gateway. AT&T will only grant a DHCP lease to the MAC they assigned your device. In my environment, it's:ONT_IF='bce0' # NIC -> ONT / Outside RG_IF='ue0' # NIC -> Residential Gateway's ONT port RG_ETHER_ADDR='xx:xx:xx:xx:xx:xx' # MAC address of Residential Gateway -
Copy
bin/pfatt.shto/root/bin(or any directory):ssh root@pfsense mkdir /root/bin scp bin/pfatt.sh root@pfsense:/root/bin/ ssh root@pfsense chmod +x /root/bin/pfatt.shNow edit your
/conf/config.xmlto include<earlyshellcmd>/root/bin/pfatt.sh</earlyshellcmd>above</system>.NOTE: If you have the 5268AC, you'll also need to install
pfatt-5268.shdue to issue #5. The script monitors your connection and disables or enables the EAP bridging as needed. It's a hacky workaround, but it enables you to keep your 5268AC connected, avoid EAP-Logoffs and survive reboots. Consider changing thePING_HOSTinpfatt-5268AC.shto a reliable host. Then perform these additional steps to install:Copy
bin/pfatt-5268ACto/usr/local/etc/rc.d/Copy
bin/pfatt-5268AC.shto/root/bin/:scp bin/pfatt-5268AC root@pfsense:/usr/local/etc/rc.d/pfatt-5268AC.sh scp bin/pfatt-5268AC.sh root@pfsense:/root/bin/ ssh root@pfsense chmod +x /usr/local/etc/rc.d/pfatt-5268AC.sh /root/bin/pfatt-5268AC.sh -
Connect cables:
Prepare for console access.
Reboot.
- Configure DUID-EN to 3561
00:00:00. - Save
- Go to Interfaces > WAN
- Enable Do not wait for a RA
- Save
- Go to Interfaces > LAN
- Save
- Save
- Save
- ng_ether
- ng_eiface
- ng_one2many
- ng_vlan
- ng_etf
Issue
ue0:
- modify pfatt.sh to set OPNSENSE='yes'
- do NOT install the ng_etf.ko, as OPNSense is based on HardenedBSD 11.2, which is in turn based on FreeBSD 11.2
- put the pfatt.sh script into
/usr/local/etc/rc.syshook.d/earlyas99-pfatt.sh - do NOT modify config.xml, nor do any of the duid stuff
TODO
