Add line in IPv6 WAN configuration steps to enable "Request only an IPv6 prefix" so that the firewall itself can access the IPv6 internet. |
| bin | ||
| img | ||
| U-VERSE_TV.md | ||
bin/pfatt.shas noted below.$RG_ETHER_ADDRshould match the MAC address of your Residential Gateway. AT&T will only grant a DHCP lease to the MAC they assigned your device. In my environment, it's:ONT_IF='xx0' # NIC -> ONT / Outside RG_IF='xx1' # NIC -> Residential Gateway's ONT port RG_ETHER_ADDR='xx:xx:xx:xx:xx:xx' # MAC address of Residential Gateway -
Copy
bin/pfatt.shto/root/bin(or any directory):ssh root@pfsense mkdir /root/bin scp bin/pfatt.sh root@pfsense:/root/bin/ ssh root@pfsense chmod +x /root/bin/pfatt.shNOTE: If you have the 5268AC, you'll also need to install
pfatt-5268AC-startup.shandpfatt-5268.sh. The scripts monitor your connection and disable or enable the EAP bridging as needed. It's a hacky workaround, but it enables you to keep your 5268AC connected, avoid EAP-Logoffs and survive reboots. Consider changing thePING_HOSTinpfatt-5268AC.shto a reliable host. Then perform these additional steps to install:scp bin/pfatt-5268AC-startup.sh root@pfsense:/usr/local/etc/rc.d/pfatt-5268AC-startup.sh scp bin/pfatt-5268AC.sh root@pfsense:/root/bin/ ssh root@pfsense chmod +x /usr/local/etc/rc.d/pfatt-5268AC-startup.sh /root/bin/pfatt-5268AC.sh -
Command: /root/bin/pfatt.sh Shellcmd Type: earlyshellcmdThis can also be acomplished by manually editing your pfSense /conf/config.xml file. Add /root/bin/pfatt.sh above . This method is not recommended and is frowned upon by pfSense team.
Connect cables:
Prepare for console access.
Reboot.
- Configure DUID-EN to 3561
00:00:00. - Save
- Go to Interfaces > WAN
- Enable Do not wait for a RA
- Save
- Go to Interfaces > LAN
- Save
- Save
- Save
- ng_ether
- ng_eiface
- ng_one2many
- ng_vlan
- ng_etf
Issue
ue0:
- use file opnatt.sh
/usr/local/etc/rc.syshook.d/earlyas99-opnatt.sh - do NOT modify config.xml, nor do any of the duid stuff
- pyrodex - for IPv6 - ?
