| bin | ||
| img | ||
- Once the authentication completes, you'll be able to properly "talk" to the outside. However, all of your traffic will need to be tagged with VLAN ID 0 (a.k.a. VLAN Priority Tagging[1][2]) before the IP gateway will respond.
Bypass Procedure: Supplicant Method
Notes
Note that EAP-TLS authentication authorizes the device, not the subscriber. Meaning, any authorized device (BGW210) can be used to authorize the link. It does not have to match the residential gateway assigned to your account. For example, a BGW210 purchased of eBay can authorize the link. The subscriber's service is authorized separately (probably by the DHCP MAC and/or ONT serial number).
- Netgraph creates an interface for us called ngeth0. This interface is connected to vlan0 which is configured to tag all traffic as VLAN0 before sending it on to the ONT interface.
- wpa_supplicant binds to ngeth0 and initiates 802.1X EAP-TLS authentication
- pfSense can then be configured to use ngeth0 as the WAN interface.
- Spoof the MAC address of the residential gateway and request a DHCP lease on ngeth0. The packets get tagged as VLAN0 and exit to the ONT.
- Now the DHCP handshake should complete and we should be on our way!
- pfSense 2.4.5 running on amd64 architecture
- Two physical network interfaces on your pfSense server
- The MAC address of your EAP-TLS Identity (from residential gateway used for certificates)
- Valid certificates to perform EAP-TLS authentication (see Extracting Certificates)
bin/pfatt.shas noted below.$RG_ETHER_ADDRshould match the MAC address of your Residential Gateway. AT&T will only grant a DHCP lease to the MAC they assigned your device.ONT_IF='xx0' # NIC -> ONT / Outside RG_ETHER_ADDR='xx:xx:xx:xx:xx:xx' # MAC address of Residential Gateway -
Copy
bin/pfatt.shto/root/bin(or any directory) and make executable:ssh root@pfsense mkdir /root/bin scp bin/pfatt.sh root@pfsense:/root/bin/ ssh root@pfsense chmod +x /root/bin/pfatt.sh -
Upload your extracted certs (see Extracting Certificates) to /conf/pfatt/wpa. You should have three files in the wpa directory as such. You may also need to match the permissions.
[2.4.4-RELEASE][root@pfsense.knox.lan]/conf/pfatt/wpa: ls -al total 19 drwxr-xr-x 2 root wheel 5 Jan 10 16:32 . drwxr-xr-x 4 root wheel 5 Jan 10 16:33 .. -rw------- 1 root wheel 5150 Jan 10 16:32 ca.pem -rw------- 1 root wheel 1123 Jan 10 16:32 client.pem -rw------- 1 root wheel 887 Jan 10 16:32 private.pem -
Command: /root/bin/pfatt.sh Shellcmd Type: earlyshellcmdThis can also be acomplished by manually editing your pfSense /conf/config.xml file. Add /root/bin/pfatt.sh above . This method is not recommended and is frowned upon by pfSense team.
Connect cables:
$ONT_IFto ONT (outside)LAN NICto local switch (as normal)
Prepare for console access.
Reboot.
Certificates can be extracted by the exploitation of the residential gateway to get a root shell. Here are instructions to do so with windows by iwleonards.
Be careful, you have sole responsibility for not bricking your residential gateway.
In case they are needed, here are firmware archives: 1.0.29 Firmware Firmware archive
- Configure DUID-EN to 3561
00:00:00. - Save
- Go to Interfaces > WAN
- Enable Do not wait for a RA
- Save
- Go to Interfaces > LAN
- Save
- Save
- Save
pfatt.sh will put $ONT_IF in promiscuous mode via /sbin/ifconfig $ONT_IF promisc. I think this is necessary for everyone but I'm not sure. Turn it off if it's causing issues.
- ng_ether
- ng_eiface
- ng_one2many
- ng_vlan
- ng_etf
Issue
There are 5 total nodes:
- Inspect the various nodes and hooks.
In some circumstances, pfSense may alter your netgraph. This is especially true if pfSense manages either your $ONT_IF. If you make some interface changes and your connection breaks, check to see if your netgraph was changed.
- MonkWho - For the code that was forked. Other credits on his page
- aus - 31m9ujhbsRRZs4S64njEkw8ksFSTTDcsRU - For the original work
- iwleonards - Residential gateway certificate extraction
