MonkWho 441cc07efa
Merge pull request #1 from 0xC0ncord/master
Merge to implement latest changes
2020-05-02 14:00:06 -07:00
bin add OPNSENSE variable and skip pfSense specific stuff 2019-04-03 14:32:52 -05:00
README.md Add U-verse TV documentation 2019-08-04 16:18:08 -04:00
This repository includes my notes on enabling a true bridge mode setup with AT&T U-Verse and pfSense. This method utilizes netgraph which is a graph based kernel networking subsystem of FreeBSD. This low-level solution was required to account for the unique issues surrounding bridging 802.1X traffic and tagging a VLAN with an id of 0. I've tested and confirmed this setup works with AT&T U-Verse Internet on the ARRIS NVG589, NVG599 and BGW210-700 residential gateways (probably others too). For Pace 5268AC, see issue #5.
    tar -C / -zxvf src.txz
    make
  7. Save
  1. modify pfatt.sh to set OPNSENSE='yes'
  2. do NOT install the ng_etf.ko, as OPNSense is based on HardenedBSD 11.2, which is in turn based on FreeBSD 11.2 and has the module already installed.
  3. put the pfatt.sh script into /usr/local/etc/rc.syshook.d/early as 99-pfatt.sh
