| bin | ||
| img | ||
- Once the authentication completes, you'll be able to properly "talk" to the outside. However, all of your traffic will need to be tagged with VLAN ID 0 (a.k.a. VLAN Priority Tagging[1][2]) before the IP gateway will respond.
Supplicant Method
Outside[ONT]---[nic0]pfsense
- pfSense 2.4.5 running on amd64 architecture
- Two physical network interfaces on your pfSense server
- The MAC address of your EAP-TLS Identity (which is the same as your residential gateway if you are using its certificates)
- Valid certificates to perform EAP-TLS authentication (see Extracting Certificates)
bin/pfatt.shas noted below.$RG_ETHER_ADDRshould match the MAC address of your Residential Gateway. AT&T will only grant a DHCP lease to the MAC they assigned your device. In my environment, it's:ONT_IF='xx0' # NIC -> ONT / Outside RG_IF='xx1' # NIC -> Residential Gateway's ONT port RG_ETHER_ADDR='xx:xx:xx:xx:xx:xx' # MAC address of Residential Gateway -
Copy
bin/pfatt.shto/root/bin(or any directory):ssh root@pfsense mkdir /root/bin scp bin/pfatt.sh root@pfsense:/root/bin/ ssh root@pfsense chmod +x /root/bin/pfatt.sh -
Upload your extracted certs (see Extracting Certificates) to /conf/pfatt/wpa. You should have three files in the wpa directory as such. You may also need to match the permissions.
[2.4.4-RELEASE][root@pfsense.knox.lan]/conf/pfatt/wpa: ls -al total 19 drwxr-xr-x 2 root wheel 5 Jan 10 16:32 . drwxr-xr-x 4 root wheel 5 Jan 10 16:33 .. -rw------- 1 root wheel 5150 Jan 10 16:32 ca.pem -rw------- 1 root wheel 1123 Jan 10 16:32 client.pem -rw------- 1 root wheel 887 Jan 10 16:32 private.pem -
Command: /root/bin/pfatt.sh Shellcmd Type: earlyshellcmdThis can also be acomplished by manually editing your pfSense /conf/config.xml file. Add /root/bin/pfatt.sh above . This method is not recommended and is frowned upon by pfSense team.
Connect cables:
$ONT_IFto ONT (outside)LAN NICto local switch (as normal)
Prepare for console access.
Reboot.
- Configure DUID-EN to 3561
00:00:00. - Save
- Go to Interfaces > WAN
- Enable Do not wait for a RA
- Save
- Go to Interfaces > LAN
- Save
- Save
- Save
- ng_ether
- ng_eiface
- ng_one2many
- ng_vlan
- ng_etf
Issue
ue0:
- use file opnatt.sh
/usr/local/etc/rc.syshook.d/earlyas99-opnatt.sh - do NOT modify config.xml, nor do any of the duid stuff
- pyrodex - for IPv6 - ?
