2022-06-28 08:14:39 -05:00
bin Supplicant OPNsense testing 2020-05-26 22:15:32 -07:00
wpa Updating missing supplicant files 2020-05-06 04:06:22 -07:00
README.md Update README.md 2022-06-28 08:14:22 -05:00
This repository includes my notes on enabling a true bridge mode setup with AT&T U-Verse and OPNsense. This method utilizes netgraph which is a graph based kernel networking subsystem of FreeBSD. This low-level solution was required to account for the unique issues surrounding bridging 802.1X traffic and tagging a VLAN with an id of 0.
There are a few other methods to accomplish true bridge mode, so be sure to see what easiest for you. True Bridge Mode is also possible in a Linux via ebtables or using hardware with a VLAN swap trick.
  • Motorola NVG589
  • Arris NVG599
  • Arris BGW210
  • Pace 5268AC
To bypass the gateway using OPNsense, we can emulate the standard procedure. If we connect our Residential Gateway and ONT to our OPNsense box, we can bridge the 802.1/X authentication sequence, tag our WAN traffic as VLAN0, and request a public IPv4 via DHCP using a spoofed MAC address.
Bridge Method
[nic0] OPNsense [nic1]
  3. If the packet matches an 802.1/X type (which is does), it is passed to the ONT interface. If it does not, the packet is discarded. This prevents our Residential Gateway from initiating DHCP. We want OPNsense to handle that.
  6. OPNsense can then be configured to use ngeth0 as the WAN interface.
Supplicant Method
Outside[ONT]---[nic0]pfsense
Bridge EAP-TLS
EAP_MODE="bridge"
Easiest method
Supplicant EAP-TLS
EAP_MODE="supplicant"
  • pfSense 2.4.x
For bridge mode:
For supplicant mode:
If you only have two NICs, you can buy this cheap USB 100Mbps NIC from Amazon as your third. It has the Asix AX88772 chipset, which is supported in FreeBSD with the axe driver. I've confirmed it works in my setup. The driver was already loaded and I didn't have to install or configure anything to get it working.
Also, don't worry about the poor performance of USB or 100Mbps NICs. This third NIC will only send/recieve a few packets periodicaly to authenticate your Router Gateway. The rest of your traffic will utilize your other (and much faster) NICs.
  2. Copy bin/opnatt.sh to /user/local/etc/rc.syshook.d/early/99-opnatt.sh (or any directory):
    scp bin/pfatt.sh root@OPNsense:/user/local/etc/rc.syshook.d/early/99-opnatt.sh
    ssh root@OPNsense chmod +x /user/local/etc/rc.syshook.d/early/99-opnatt.sh
    scp bin/pfatt-5268AC-startup.sh root@OPNsense:/usr/local/etc/rc.d/pfatt-5268AC-startup.sh
    scp bin/pfatt-5268AC.sh root@OPNsense:/root/bin/
    ssh root@OPNsense chmod +x /usr/local/etc/rc.d/pfatt-5268AC-startup.sh /root/bin/pfatt-5268AC.sh
  3. The pfatt.sh script will start with the boot process due to it's placement in /user/local/etc/rc.syshook.d/early/.
  7. OPNsense will detect new interfaces on bootup. Follow the prompts on the console to configure ngeth0 as your OPNsense WAN. Your LAN interface should not normally change. However, if you moved or re-purposed your LAN interface for this setup, you'll need to re-apply any existing configuration (like your VLANs) to your new LAN interface. OPNsense does not need to manage $RG_IF or $ONT_IF. I would advise not enabling those interfaces in OPNsense as it can cause problems with the netgraph.
  4. Configure IPv6 Prefix ID to 0. You CAN use IPv6 Prefix id 0, as OPNSense does NOT assign a routeable IPv6 address to ngeth0
If the VLAN0 traffic is being properly handled, next OPNsense will need to request an IP. ngeth0 needs to DHCP using the authorized MAC address. You should see an untagged DCHP request on ngeth0 carry over to the $ONT_IF interface tagged as VLAN0. Then you should get a DHCP response and you're in business.
FreeBSD
