| bin | ||
| img | ||
Quick Setup
- You need at least three network interfaces on your pfSense server.
- pfSense 2.4.3 (confirmed working, other versions should work but YMMV)
Copy the
bin/ng_etf.kokernel module to/boot/kernelon your pfSense box (because it isn't included):a) Use the pre-compiled kernel module from me, a random internet stranger:
scp bin/ng_etf.ko root@pfsense:/boot/kernel/ chmod 555 /boot/kernel/ng_etf.kob) Or you, a responsible sysadmin, can compile the module yourself from a trusted FreeBSD 11.1 machine:
fetch ftp://ftp.freebsd.org/pub/FreeBSD/releases/amd64/amd64/11.1-RELEASE/src.txz tar -C / -zxvf src.txz cd /usr/src/sys/modules/netgraph make scp etf/ng_etf.ko root@pfsense:/boot/kernel/ ssh root@pfsense chmod 555 /boot/kernel/ng_etf.ko -
bin/pfatt.shas noted below.$RG_ETHER_ADDRshould match the MAC address of your Residential Gateway. AT&T will only grant a DHCP lease to the MAC they assigned your device. In my environment, it's:ONT_IF='bce0' # NIC -> ONT RG_IF='ue0' # NIC -> RG RG_ETHER_ADDR='xx:xx:xx:xx:xx:xx' # MAC address of Residential Gateway -
Copy
bin/pfatt.shto/usr/local/etc/rc.dto enable it to run at boot:scp bin/pfatt.sh root@pfsense:/usr/local/etc/rc.d/ ssh root@pfsense chmod +x /usr/local/etc/rc.d/pfatt.sh -
Connect cables:
$RG_IFto Residiential Gateway$ONT_IFto ONTLAN NICto local switch (as normal)
Prepare for console access.
Reboot.
ngeth0as your pfSense WAN. Your LAN interface should not change. -
ngeth0) to DHCP using the MAC address of your Residential Gateway. -
TODO: IPv6
If every thing is setup correctly, netgraph should be bridging EAP traffic between the ONT and RG, and tagging the WAN traffic with VLAN0.
Troubleshoot
tcpdump -ei ngeth0
- ng_ether
- ng_eiface
- ng_one2many
- ng_vlan
- ng_etf
Issue
- Inspect the node and hooks. Example for
ue0:
TODO
- rajl - 1H8CaLNXembfzYGDNq1NykWU3gaKAjm8K5
