| bin | ||
| img | ||
Quick Setup
- You need at least three network interfaces on your pfSense server.
- pfSense 2.4.3 (confirmed working, other versions should work but YMMV)
Logon to your pfSense box via SSH.
Copy the
bin/ng_etf.kokernel module to/boot/kernel(because it isn't included with pfSense):a) Use the pre-compiled kernel module from me, a random internet stranger:
scp bin/ng_etf.ko root@pfsense:/boot/kernel/ chmod 555 /boot/kernel/ng_etf.kob) Or you, a responsible sysadmin, can compile the module yourself from a trusted FreeBSD 11.1 machine:
fetch ftp://ftp.freebsd.org/pub/FreeBSD/releases/amd64/amd64/11.1-RELEASE/src.txz tar -C / -zxvf src.txz cd /usr/src/sys/modules/netgraph make scp etf/ng_etf.ko root@pfsense:/boot/kernel/ ssh root@pfsense chmod 555 /boot/kernel/ng_etf.ko -
bin/pfatt.shas noted below.$RG_ETHER_ADDRshould match the MAC address of your Residential Gateway. AT&T will only grant a DHCP lease to the MAC they assigned your device.ONT_IF='em0' RG_IF='em1' RG_ETHER_ADDR='xx:xx:xx:xx:xx:xx' -
Copy
bin/pfatt.shto/usr/local/etc/rc.dto enable it to run at boot:scp bin/pfatt.sh root@pfsense:/usr/local/etc/rc.d/ ssh root@pfsense chmod +x /usr/local/etc/rc.d/pfatt.sh -
Connect cables:
$RG_IFto Residiential Gateway$ONT_IFto ONTLAN NICto local switch (as normal)
Prepare for console access.
Reboot.
ngeth0as your pfSense WAN. Your LAN interface should not change. -
Configure the WAN interface (
ngeth0) to DHCP -
Configure your WAN interface to use the MAC address of your Residential Gateway.
Ensure that
$RG_IFis added as an interface and enabled.
If every thing is setup correctly, netgraph should be bridging EAP traffic between the ONT and RG, and tagging the WAN traffic with VLAN0.
Troubleshoot
tcpdump -ei ngeth0
If the VLAN0 traffic is being properly handled, next pfSense will need to request an IP. ngeth0 needs to DHCP using the authorized MAC address. You should see an untagged DCHP request on ngeth0 carry over to the $ONT_IF interface gged as VLAN0. Then you
should get a DHCP response and you're in business.
The netgraph system provides a uniform and modular system for the implementation of kernel objects which perform various networking functions.
- ng_ether
- ng_eiface
- ng_one2many
- ng_vlan
- ng_etf
Issue
ngctl listto list netgraph nodes. Inspectpfatt.shto verify the netgraph output matches the configuration in the script.
TODO
- https://forum.pfsense.org/index.php?topic=111043.0
- http://www.dslreports.com/forum/r31632582-
- rajl - 1H8CaLNXembfzYGDNq1NykWU3gaKAjm8K5
