2020-09-28 11:36:21 -04:00
README.md Update README.md 2020-09-28 11:36:21 -04:00
Static IP block configuration
1:1 Nat:
  • Navigate to Firewall > NAT > 1:1.
  • Create a new 1:1 NAT rule with the following values. Interface: WAN
  • External Network: your desired usable static IP
  • Internal IP: (Single Host or Network) IP of the LAN host or network that you want to have the static IP.
  • Make sure you set the submask accordingly (single devices use /32) a /32 only gives you one address.
