| bin | ||
| img | ||
This repository includes my notes on enabling a true bridge mode setup with AT&T U-Verse and pfSense. This method utilizes netgraph which is a graph based kernel networking subsystem of FreeBSD. This low-level solution was required to account for the unique issues surrounding bridging 802.1X traffic and tagging a VLAN with an id of 0. I've tested and confirmed this setup works with AT&T U-Verse Internet on the ARRIS NVG589 and BGW210-700 residential gateways (probably others too).
Standard Procedue
- All traffic on the ONT is protected with 802.1/X. So in order to talk to anything, the Router Gateway must first perform the authentication procedure. This process uses a unique ceritificate that is hardcoded on your residential gateway.
- Once the authentication completes, you'll be to properly "talk" to the outside. But strangely, all of your traffic will need to be tagged with VLAN id 0 before the IP gateway will respond. I believe VLAN0 is an obscure Cisco feature of 802.1Q CoS, but I'm not really sure.
- The Residential Gateway initates a 802.1/X EAPOL-START.
- pfSense 2.4.3 (confirmed working, other versions should work but YMMV)
Copy the
bin/ng_etf.kokernel module to/boot/kernelon your pfSense box (because it isn't included):a) Use the pre-compiled kernel module from me, a random internet stranger:
scp bin/ng_etf.ko root@pfsense:/boot/kernel/ ssh root@pfsense chmod 555 /boot/kernel/ng_etf.kob) Or you, a responsible sysadmin, can compile the module yourself from another, trusted FreeBSD machine. You cannot build packages directly on pfSense. Your FreeBSD version should match that of your pfSense version. (Example: pfSense 2.4.3 = FreeBSD 11.1)
# from a FreeBSD machine (not pfSense!) fetch ftp://ftp.freebsd.org/pub/FreeBSD/releases/amd64/amd64/11.1-RELEASE/src.txz tar -C / -zxvf src.txz cd /usr/src/sys/modules/netgraph make scp etf/ng_etf.ko root@pfsense:/boot/kernel/ ssh root@pfsense chmod 555 /boot/kernel/ng_etf.ko -
bin/pfatt.shas noted below.$RG_ETHER_ADDRshould match the MAC address of your Residential Gateway. AT&T will only grant a DHCP lease to the MAC they assigned your device. In my environment, it's:ONT_IF='bce0' # NIC -> ONT / Outside RG_IF='ue0' # NIC -> Residential Gateway's ONT port RG_ETHER_ADDR='xx:xx:xx:xx:xx:xx' # MAC address of Residential Gateway -
Copy
bin/pfatt.shto/root/bin(or any directory):scp bin/pfatt.sh root@pfsense:/usr/local/etc/rc.d/ ssh root@pfsense chmod +x /root/bin/pfatt.shNow edit your
config.xmlto include<earlyshellcmd>/root/bin/pfatt.sh</earlyshellcmd>above</system> -
Connect cables:
$RG_IFto Residiential Gateway on the ONT port (not the LAN ports!)$ONT_IFto ONT (outside)LAN NICto local switch (as normal)
Prepare for console access.
Reboot.
ngeth0as your pfSense WAN. Your LAN interface should not change. pfSense does not need to manage$RG_IFor$ONT_IF. I would advise not enabling those interfaces in pfSense as it can cause problems with the netgraph. -
- Configure DUID-EN to 3561
- Configure your IANA Private Enterprise Number. This number is unique for each customer and (I believe) based off your Residential Gateway serial number. I grabbed mine off a pcap of the Residential Gateway. Fire up Wireshark and look for the value in DHCPv6 > Client Identifier > Identifier. Add the value as colon separated hex values
00:00:00. - Save
- Go to Interfaces > WAN
- Enable Advanced Configuration
- Enable Configuration Override
- Enable Debug
- Enable Do not wait for a RA
- Configure Configuration File to
/cf/conf/att_dhcp6.conf - Save
Configuration File
- Logon to your pfsense box and add the following file to
/cf/conf/att_dhcp6.confchanging the WAN / LAN interface names to match your setup:
# WAN
interface ngeth0 {
send ia-na 1; # request stateful address
send ia-pd 1; # request prefix delegation - LAN
request domain-name-servers;
id-assoc na 1 { };
id-assoc pd 1 {
prefix ::/60 infinity;
# LAN
prefix-interface bce1 {
sla-id 0;
sla-len 4;
- Go to Interfaces > LAN
- Configure IPv6 Prefix ID to 0
- Save
- Configure a range of ::1000 to ::2000
- Add a few IPv6 DNS servers
- Save
- Save
pfatt.sh will put $RG_IF in promiscuous mode via /sbin/ifconfig $RG_IF promisc. Otherwise, the EAP packets would not bridge. I think this is necessary for everyone but I'm not sure. Turn it off if it's casuing issues.
- ng_ether
- ng_eiface
- ng_one2many
- ng_vlan
- ng_etf
Issue
ue0:
TODO
