2022-02-21 06:30:45 -05:00
bin Update pfatt.sh 2021-01-08 17:00:03 -06:00
README.md Update README.md 2022-02-20 11:02:58 -06:00
  • pfSense 2.5.1+ running on amd64 architecture
Notes
Note that EAP-TLS authentication authorizes the device, not the subscriber. Meaning, any authorized device (e.g., BGW210) can be used to authorize the link. It does not have to match the residential gateway assigned to your account. For example, a BGW210 purchased of eBay can authorize the link. The subscriber's service is authorized separately (probably by the DHCP MAC and/or ONT serial number).
High Level Steps
Detailed Steps
  1. Edit the following configuration variables in bin/pfatt.sh as noted below. $RG_ETHER_ADDR should match the MAC address of your Residential Gateway. AT&T will only grant a DHCP lease to the MAC they assigned your device.
    CA_PEM='xxx.pem' # Replace xxx with file name of gateway certificate
    CLIENT_PEM='xxx.pem' # Replace xxx with file name of gateway certificate
    PRIVATE_PEM='xxx.pem' # Replace xxx with file name of gateway certificate
  2. Copy bin/pfatt.sh to /root/bin (or any directory) and make executable:
  3. Extracting Certificates: Certificates can be extracted by the exploitation of the residential gateway to get a root shell. Here are instructions to do so in windows by iwleonards.
    Be careful, you have sole responsibility for not bricking your residential gateway.
    In case they are needed, here are firmware archives:
  4. Upload your extracted certs (see Extracting Certificates) to /conf/pfatt/wpa. You should have three files in the wpa directory as such. You may also need to match the permissions. Do this with sudo chmod -R 0600 /conf/pfatt/wpa
    [2.5.2-RELEASE][root@pfsense.knox.lan]/conf/pfatt/wpa: ls -al
    total 19
  5. To start pfatt.sh script at the beginning of the boot process pfSense team recommends you use a package called shellcmd. Use pfSense package installer to find and install it. Once you have shellcmd package installed you can find it in Services > Shellcmd. Now add a new command and fill it up accordingly (make sure to select earlyshellcmd from a dropdown):
    This can also be accomplished by manually editing your pfSense /conf/config.xml file. Add /root/bin/pfatt.sh above. This method is not recommended and is frowned upon by pfSense team.
  6. Connect cables:
  7. Prepare for console access.
  8. Reboot.
  9. pfSense will detect new interfaces on bootup. Follow the prompts on the console to configure ngeth0 as your pfSense WAN. Your LAN interface should not normally change. However, if you moved or re-purposed your LAN interface for this setup, you'll need to re-apply any existing configuration (like your VLANs) to your new LAN interface. pfSense does not need to manage $ONT_IF. I would advise not enabling those interfaces in pfSense as it can cause problems with the netgraph.
  10. In the webConfigurator, configure the WAN interface (ngeth0) to DHCP using the MAC address of your Residential Gateway.
This setup assumes you have a fairly recent version of pfSense. I'm using 2.5.2.
Use tcpdump to watch the authentication, vlan and dhcp bypass process (see above). Run tcpdumps on the $ONT_IF interface:
You should see some more EAP packets from the $ONT_IF interface as it negotiates 802.1/X EAP authentication.
pfatt.sh will put $ONT_IF in promiscuous mode via /sbin/ifconfig $ONT_IF promisc. I think this is necessary for everyone but I'm not sure. Turn it off if it's causing issues.
There are 5 total nodes:
  1. Inspect the various nodes and hooks.
In some circumstances, pfSense may alter your netgraph. This is especially true if pfSense manages either your $ONT_IF. If you make some interface changes and your connection breaks, check to see if your netgraph was changed.
  • iwleonards - Residential gateway certificate extraction
