| bin | ||
| img | ||
This repository includes my notes on enabling a true bridge mode setup with AT&T U-Verse and pfSense. This method utilizes netgraph which is a graph based kernel networking subsystem of FreeBSD. This low-level solution was required to account for the unique issues surrounding bridging 802.1X traffic and tagging a VLAN with an id of 0. I've tested and confirmed this setup works with AT&T U-Verse Internet on the ARRIS NVG589 and BGW210-700 residential gateways (probably others too).
Standard Procedue
- All traffic on the ONT is protected with 802.1/X. So in order to talk to anything, the Router Gateway must first perform the authentication procedure. This process uses a unique ceritificate that is hardcoded on your residential gateway.
- Once the authentication completes, you'll be to properly "talk" to the outside. But strangely, all of your traffic will need to be tagged with VLAN id 0 before the IP gateway will respond. I believe VLAN0 is an obscure Cisco feature of 802.1Q CoS, but I'm not really sure.
- The Residential Gateway initates a 802.1/X EAPOL-START.
- pfSense 2.4.3 (confirmed working, other versions should work but YMMV)
If you only have two NICs, you can buy this cheap USB NIC one from Amazon as your third. I've confirmed it works in my setup. It is compatible with FreeBSD 11.1 and I didn't have to install anything to get it working. Also, don't worry about the poor performance of USB NICs. This third NIC will only send/recieve a few packets periodicaly to authenticate your Router Gateway. The rest of your traffic will utilize your other (and much faster) NICs.
Copy the
bin/ng_etf.kokernel module to/boot/kernelon your pfSense box (because it isn't included):a) Use the pre-compiled kernel module from me, a random internet stranger:
scp bin/ng_etf.ko root@pfsense:/boot/kernel/ ssh root@pfsense chmod 555 /boot/kernel/ng_etf.kob) Or you, a responsible sysadmin, can compile the module yourself from another, trusted FreeBSD machine. You cannot build packages directly on pfSense. Your FreeBSD version should match that of your pfSense version. (Example: pfSense 2.4.3 = FreeBSD 11.1)
# from a FreeBSD machine (not pfSense!) fetch ftp://ftp.freebsd.org/pub/FreeBSD/releases/amd64/amd64/11.1-RELEASE/src.txz tar -C / -zxvf src.txz cd /usr/src/sys/modules/netgraph make scp etf/ng_etf.ko root@pfsense:/boot/kernel/ ssh root@pfsense chmod 555 /boot/kernel/ng_etf.ko -
bin/pfatt.shas noted below.$RG_ETHER_ADDRshould match the MAC address of your Residential Gateway. AT&T will only grant a DHCP lease to the MAC they assigned your device. In my environment, it's:ONT_IF='bce0' # NIC -> ONT / Outside RG_IF='ue0' # NIC -> Residential Gateway's ONT port RG_ETHER_ADDR='xx:xx:xx:xx:xx:xx' # MAC address of Residential Gateway -
Copy
bin/pfatt.shto/root/bin(or any directory):scp bin/pfatt.sh root@pfsense:/usr/local/etc/rc.d/ ssh root@pfsense chmod +x /root/bin/pfatt.shNow edit your
config.xmlto include<earlyshellcmd>/root/bin/pfatt.sh</earlyshellcmd>above</system> -
Connect cables:
$RG_IFto Residiential Gateway on the ONT port (not the LAN ports!)$ONT_IFto ONT (outside)LAN NICto local switch (as normal)
Prepare for console access.
Reboot.
ngeth0as your pfSense WAN. Your LAN interface should not change. pfSense does not need to manage$RG_IFor$ONT_IF. I would advise not enabling those interfaces in pfSense as it can cause problems with the netgraph. -
- Configure DUID-EN to 3561
- Configure your IANA Private Enterprise Number. This number is unique for each customer and (I believe) based off your Residential Gateway serial number. I grabbed mine off a pcap of the Residential Gateway. Fire up Wireshark and look for the value in DHCPv6 > Client Identifier > Identifier. Add the value as colon separated hex values
00:00:00. - Save
- Go to Interfaces > WAN
- Enable Advanced Configuration
- Enable Configuration Override
- Enable Debug
- Enable Do not wait for a RA
- Configure Configuration File to
/cf/conf/att_dhcp6.conf - Save
Configuration File
- Logon to your pfsense box and add the following file to
/cf/conf/att_dhcp6.confchanging the WAN / LAN interface names to match your setup:
# WAN
interface ngeth0 {
send ia-na 1; # request stateful address
send ia-pd 1; # request prefix delegation - LAN
request domain-name-servers;
id-assoc na 1 { };
id-assoc pd 1 {
prefix ::/60 infinity;
# LAN
prefix-interface bce1 {
sla-id 0;
sla-len 4;
- Go to Interfaces > LAN
- Configure IPv6 Prefix ID to 0
- Save
- Configure a range of ::1000 to ::2000
- Add a few IPv6 DNS servers
- Save
- Save
pfatt.sh will put $RG_IF in promiscuous mode via /sbin/ifconfig $RG_IF promisc. Otherwise, the EAP packets would not bridge. I think this is necessary for everyone but I'm not sure. Turn it off if it's casuing issues.
- ng_ether
- ng_eiface
- ng_one2many
- ng_vlan
- ng_etf
Issue
ue0:
TODO
