12 KiB
- MySQL 5.7 (full support)
- MySQL 5.6 (full support)
- MySQL 5.5 (full support)
- MariaDB 10.1 (full support)
- MariaDB 10.0 (full support)
Security recommandations
- Fedora Core 23 / MySQL 5.6
- Fedora Core 23 / MySQL 5.7
- vagrant up
- Start vagrant
- vagrant up
