MySQLTuner-perl/README.md
Jean-Marie RENOUARD 57358fc7c9 Update FAQ section
2023-03-21 15:38:28 +01:00
23 KiB
  • MariaDB 10.6 (full support)
*** MINIMAL REQUIREMENTS ***
Question: What are the prerequisites for running MySQL tuner ? Before running MySQL tuner, you should have the following:
  • A MySQL server installation
