2015-06-16 15:45:34 +02:00
CONTRIBUTING.md Adding a small CONTRIBUTING file 2015-06-16 15:20:36 +02:00
mysqltuner.pl Adding advice for buffer_pool_size_instances variables for 5.6.6+ mysql version 2015-06-15 16:22:51 +02:00
README.md README format errorswq 2015-06-16 15:45:34 +02:00
  • MySQL 5.5 (partial support)
  • MySQL 5.6 (partial support)
  • MySQL 6.0 (partial support)
* OS and OS version
* Exact MySQL version
* The full text of the error
