4.2 KiB
- MySQL 5.4 (not fully tested, partially supported)
- MySQL 5.5 (partial support)
- MySQL 5.6 (partial support)
- MySQL 6.0 (partial support)
- MariaDB 10.x (partial support)
- Windows is not supported at this time
- Unrestricted read access to the MySQL server (OS root access recommended for MySQL < 5.0)
* OS and OS version
* Exact MySQL version
* The full text of the error
